1982 Toyota STARLET
saw this on the local Craigslist
1982 Toyota Starlet
1982 Toyota Starlet - $2000 (Ferndale)
1982 Toyota Starlet
condition: fair
cylinders: 4 cylinders
drive: rwd
fuel: gas
odometer: 126000
paint color: yellow
title status: clean
transmission: manual
type: hatchback
Solid car has a few issues . One family owned. Not sure what it's worth but have to start some where. $2000.00
124766 miles
only one small rust spot that I am aware of shown in one of the photo's
Had the carb rebuilt a few months ago and was running good. Now it seams the fuel tank has water and possibly rust and I believe some has made its way into the carb as it won't keep running. Up until that happened it was driveable.
The transmission has a bad bearing and makes noise . I have another tranny from a local junk yard that I believe should be good. I have a new clutch that I was going to install when I changed the tranny.
The rear hatch is from a different car as the original glass shattered one day. I believe all the glass is good.The heater control unit fell apart.New fuel pump.The wheels and tires shown in the first photo are from a Datsun and the offset is not correct for the starlet. The original wheels with worn tires are on the car now. I have another good set of the correct size tires mounted on wheels that don't fit the starlet.I had planned on restoring it etc.. but it the way things are going I'll probably never get to it.I believe all the electrical works.
Has factory AC •do NOT contact me with unsolicited services or offers
post id: 5207376328
posted: 20 days ago
updated: 19 days ago
2005 GTO 6.0 V8 (600hp)
1991 Geo Metro 1.0 3/5 base
2010 Prius II (replaced 2001 Tahoe 5.3 V8 April 2014)
1994 F-350 7.3 TurboDiesel (Rollin' Coal)
