Old 04-23-2017, 03:53 AM   #1 (permalink)
beastie - '89 toyota hilux dolphin motorhome
Puggie - '98 Peugeot 406 Lx
Question Mini rear spoiler on estate
Hi am thinking about putting a horizontal spoiler on my estate where the sheet metal goes from upright to angled.
. This is bad photo of what i intend. Spoiler will be about 1 1/2". Also would spoiler on top of tail gate need to removed. Any advice good bad or indifferent gratefully received.
Thanks
Dave
Old 04-23-2017, 06:20 AM   #2 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Autodesk has free windtunnel software. You could have a look at that, it will give you an idea of what eill happen.
I found a similar model to my car on grabcad.com to use in the wind tunnel software.
Old 04-23-2017, 06:24 AM   #3 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I have no idea what your car is, and it probably does not exist where i live.
But looking at the back side it ressembles this:
https://grabcad.com/library/peugeot-206-2
http://www.autodesk.com/products/cfd/overview
Old 04-23-2017, 06:45 AM   #4 (permalink)
I suspect your car is similar to what some call an econobox.
Samples:
Car Wind Tunnel Data
Surf around the forum to find typical solutions to similar vehicles.
What ever you do either needs to be in the airflow, stepped back slightly from the surface plane, or at the surface plane (like the roof).
Doing something way at the back in a area out of the flow isn't going to do anything but rob you of time and money.
Fingie (04-24-2017)
Old 04-25-2017, 01:10 AM   #5 (permalink)
Is is anything like this?
https://en.wikipedia.org/wiki/Peugeot_406
What do you hope to accomplish?
Old 04-26-2017, 08:18 AM   #6 (permalink)
don't think that spoiler on the marked position of your picture will help a bit
Old 04-26-2017, 08:30 AM   #7 (permalink)
I have seen spoilers in the proposed location, they always looked like marketing department efforts and not something stemming from the aerodynamics lab.
Some of the old air-cooled Beetles of the 1960's were known for adding some fun looking stuff at the tail end but to little effect other than aesthetics. Such things look cool, but are of little to no value. The main value is "looking cool" in almost every case I'm thinking of.
Old 04-26-2017, 10:35 AM   #8 (permalink)
A station wagon or a van would most likely benefit from extension panels at the roof, sides, and under side. Use clear material near the tail lights.
Old 04-26-2017, 12:07 PM   #9 (permalink)
[citation needed]
Herrod Helper? Cheese grater?
Standing by for more info:
  • Is it anything like [that]?
  • What do you hope to accomplish?
  • What is the angle of the lift gate?
  • Is it plus or minus to 30°?
  • Does that orange squiggle represent a Gurney flap/spoiler?
  • Or a detached wing?
Old 04-26-2017, 02:20 PM   #10 (permalink)
Hope to keep rear screen clear and reduce drag.
Approx 70-80 degrees from horizontal.
Orange squiggle would be a lip spoiler set as close to horizontal as possiable.
The Following User Says Thank You to chefdave For This Useful Post:
freebeard (04-26-2017)
