Old 02-26-2019, 06:48 PM   #1 (permalink)
Wink AC controller command help
Old 02-28-2019, 11:47 AM   #2 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by 59Morris View Post
Do you have the source code?
If so, the .h file includes all of the commands. I remember the doc being OK to describe each of them.
I forgot to look it up last night - sorry
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
Old 02-28-2019, 04:04 PM   #3 (permalink)
Thanks for the reply.
My post here was a "newbee" mistake, and I couldn't figure out how to delete it and put it in the right spot.
Yes, I have been digging through the source code and found some answers there. I'm sure more digging will answer more questions!
I emailed Paul and confirmed the info I found was correct, but somethings are not yet functional/tested. (Like throttle-type 1) I suspect things like that are only known by the author.
Old 03-01-2019, 06:33 PM   #4 (permalink)
There is a file called "serial communications" in the package that came with the controller. It contains a lot of what I needed. Somehow I didn't equate the file with configuration help and definitions.
