Old 06-30-2011, 09:15 AM   #11 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by camopaint0707 View Post
Yes I'm aware of cowl induction but most of those are for performance. I just want a little cooler air into the engine. The air wouldn't even hit near the intake at all more like the top of the block. I would just like to know if or how bad it would mess up the aerodynamics.
I guess I was wrong about the low pressure region. I didn't know about cowl induction (I'm always learning). And I misunderstood you--I thought you were talking to about connecting the hood scoop to your intake, not just into the engine compartment.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 06-30-2011, 10:36 AM   #12 (permalink)
Quasi-Modder
Would adding a hood scoop with the opening facing the windshield cause a significant decrease in MPG's? I have a 1995 acura integra that gets a pretty hot engine and wanted to add a scoop but not if it's gonna severely hurt my fuel economy.
I am considering doing exactly the same thing. I seriously doubt whether you would notice any decrease in FE. It would also vent some of that hot air under the hood; and maybe give your radiator a little better cooling. There's only one way to find out though. Just do it and see what happens. You might surprise alot of people.
Old 06-30-2011, 12:00 PM   #13 (permalink)
Actually, since its a high pressure zone, air will come into the engine bay at the hood/windshield transition point. This means more air goes under the car to an aerodynamically dirty underside. Thus, the aero is worse. Also, I do recall reading a while ago people using spacers to prop up the back of their hood. Some actually saw worse cooling with the hood spaced up. The airflow into the engine bay increases the pressure inside the engine bay. This in turn reduces the flow through the radiator and reduces the cooling capacity.
Old 06-30-2011, 12:52 PM   #14 (permalink)
Knight - '07 Chevy Cobalt LS
Chevyteg - '95 Acura Integra LS
So your saying it would be a bad idea?
Old 06-30-2011, 03:07 PM   #15 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
What you could try is to seal the bumper to front of the radiator, so the openings have to push the air past the radiator. That should help cooling some and when you are at it straighten out any bend fins on the radiator, they make a tool to do that but a cheap comb like they give kids on picture day will work if you cut the ends off.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
