Old 11-06-2010, 09:38 PM   #1 (permalink)
Red Rabbit - '02 Honda Civic LX
90 day: 38.58 mpg (US)
Honda Civic defrost w/o A/C on
So apparently Honda thinks that the A/C needs to be on ALL the time when the defroster is on, as you are unable to turn it off while in defrost mode....
Until you do this
Works on 7th and 8th gen civics. Defroster works better with A/C on, but if you are just trying to keep it from fogging back up sometimes you don't need the A/C on to dry the air out.
The Following User Says Thank You to Schelter For This Useful Post:
endurance (11-08-2010)
Old 11-07-2010, 12:12 AM   #2 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Subaru Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '11 Surly Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
Awesome. I just pull the AC circuit fuse in my Subaru Loyale, except for July-August.
Old 11-07-2010, 05:38 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Since I never got heat working back in my IRX, I just used a squeegee. I kept it right besides the fire extinguisher for easy getting-to.
Old 11-08-2010, 12:17 PM   #4 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
There are two wires that control the electric AC clutch. Splice an appropriatly heavy switch into one of them. Mount this switch in the cabin. It should allow you to turn it off when you don't want it on.
My dad had a compressor lock up in an old truck. He just unplugged the electrical connector on the compressor.
Old 03-26-2013, 09:53 AM   #5 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
There may be downside to this with those who have fully functioning A/C units. The A/C on some cars need to be activated periodically to keep the seals and everything lubricated. Without doing this you may shorten the life of the unit quite drastically.
Just and FYI.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
The Following User Says Thank You to LeanBurn For This Useful Post:
Cobb (03-26-2013)
Old 03-27-2013, 01:20 PM   #6 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
Just and FYI.
Good point.
I've been considering rigging up a switch on the Cherokee for this. Ultimately, I think I'm just going to get rid of the A/C altogether on it.
Both of my vehicles, I've considered rigging up a switch. My focus ALWAYS runs the AC in ALL positions. Even though there's an AC button. Odd thing. There's some times where it's cool enough outside that you just want to circulate some air without running the A/C.
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 83 06-20-2015 11:30 AM
'93 Civic 40.6 mpg + Harbor Freight utility trailer, Honda CL125, Honda CH80 scoot begreen Introductions 13 08-29-2013 06:37 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
honda civic- buying advice? robots4joey General Efficiency Discussion 18 03-26-2010 03:19 PM
8th Gen. Civic manual defrost A/C control superchow DIY / How-to 0 02-02-2010 03:29 PM
