Old 11-02-2018, 06:38 PM   #21 (permalink)
Rav4 - '21 Toyota Rav4 XSE
90 day: 48.58 mpg (US)
My Subaru Outback xt has one from factory it sits between the filter and block. Though that car is far from efficient being an awd wagon with a 2.5l turbo
The Following User Says Thank You to Subaruwagon For This Useful Post:
Daox (11-02-2018)
Old 11-02-2018, 06:43 PM   #22 (permalink)
I would imagine OEMs use them on turbocharged engines to help prevent coking issues.
Old 11-02-2018, 08:50 PM   #23 (permalink)
ScanGauge <3
ThermionicScott's Avatar
Dang, now I'm wishing I had one for my Subaru!
Best tank (so far): 32 MPG
Old 11-02-2018, 09:50 PM   #24 (permalink)
Yeah it’s used as a cooler to prevent coking not warm up the oil but I’m sure it does a little of both. It would be easy for you to add one all the ej Subaru blocks have the same external dimensions all you would have to do is install the cooler and the fitting in the block, there is on hard line and three rubber 90 degree hoses possibly put a different water pump on idk if you’re pump would have the fitting the coolant pipe goes to
Daox (11-02-2018)
Old 11-02-2018, 10:18 PM   #25 (permalink)
Good to know Subaruwagon! One more source for possible parts. Thanks.
Old 11-02-2018, 10:20 PM   #26 (permalink)
Aaaand, a quick google search finds us this. $15 shipped. Not bad at all. I just have to figure out if its the same thickness as the VW cooler.
https://www.ebay.com/itm/02-05-Subar...4:pf:0&vxp=mtr
The Following User Says Thank You to Daox For This Useful Post:
Xist (12-09-2018)
Old 11-02-2018, 10:40 PM   #27 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I found a bunch of them on the Flexalite website:
https://www.flex-a-lite.com/flex-a-l...mm-thread.html
The Following 2 Users Say Thank You to oldtamiyaphile For This Useful Post:
Daox (11-02-2018), Xist (12-09-2018)
Old 11-03-2018, 12:25 PM   #28 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by teoman View Post
A vw cooled exhaust manifold would be nice. They heat up very fast.
I have one in the up!
Heats up the coolant really fast, so in turn, that should heat up the oil pretty quickly, too !
Old 11-03-2018, 01:05 PM   #29 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I am curious if grille blocking is a nono if one has one of those.
My mothers passat heats up very quickly aswell.
Old 11-04-2018, 11:53 AM   #30 (permalink)
euromodder's Avatar
As always, watch engine temperatures when blocking the grille !
