Advisory for Chrysler Returnless Fuel Supply Systems
Chrysler vehicles with returnless fuel supply systems will have MPGuino fuel economy figures that will be thrown off by an average of 3% from actual, on an otherwise properly calibrated MPGuino. This is currently unavoidable. Tweaking MPGuino fuel calibration on these vehicles will only minimize this error, but will not eliminate it. Ford (and presumably other vehicle manufacturers) returnless fuel supply systems do not have this problem.
If your returnless fuel supply system features a fuel pressure sensor and a fuel pump that is controlled by the engine computer to regulate fuel pressure, then you do not have this problem. If your returnless fuel supply system features an in-tank mechanical fuel pressure regulator, you have this problem. The reason is this: In performing fuel delivery calculations, MPGuino assumes a fuel pressure that is a constant value above intake manifold pressure. This assumption is perfectly valid for older vehicles that have a return-style fuel supply system, because they have a mechanical fuel pressure regulator that is controlled by engine vacuum. The regulator will cause a constant pressure difference across the fuel injectors, regardless of engine vacuum, such that the same amount of fuel will be squirted for a given injector cycle time every time. Returnless fuel supply systems were introduced by the major auto manufacturers as a way to comply with pollution regulations regarding unburnt fuel emissions. Currently, there are two different returnless system designs in use. The first system design, introduced by Chrysler, uses an in-tank mechanical fuel pressure regulator that does not get connected to engine vacuum. This regulator regulates fuel pressure to a constant 58 psig above ambient atmospheric pressure, instead. This is mechanically a very simple design, but it does require that the engine computer take this into account when performing fuel delivery calculations, as there is now a variable pressure difference across the fuel injectors. This difference is directly related to engine vacuum. For a given injector cycle time, more fuel will be squirted out of the fuel injectors with a high engine vacuum, than would be with a low engine vacuum. Therefore, for this fuel supply system, the MPGuino fuel pressure assumption is not valid, and MPGuino fuel delivery calculations may be in error by as much as 7%, on an otherwise perfectly calibrated unit. The second system design, introduced by Ford, and also used by other vehicle manufacturers, uses no mechanical fuel pressure regulator. Instead, fuel pressure is regulated directly by the engine computer. The engine computer does this by reading a fuel pressure sensor, then electronically controlling the fuel pump to obtain a desired fuel pressure. This system regulates fuel pressure identically to an older return-style mechanical system that uses a fuel pressure regulator controlled by engine vacuum. This system will cause a constant pressure difference across the fuel injectors, regardless of engine vacuum, such that the same amount of fuel will be squirted for a given injector cycle time every time. The engine computer has simpler fuel delivery calculations as a result, but it does have to have an additional task of controlling the fuel pump to regulate fuel pressure. Therefore, for this fuel supply system, the MPGuino fuel pressure assumption is valid, and MPGuino fuel delivery calculations should not be in error on an otherwise perfectly calibrated unit. --- Original post: I bought an MPGuino a few days ago, and received it in the mail. Impressive-looking little unit. However, I've had less than stellar luck with having one question answered: Does MPGuino handle returnless fuel lines? That's when either an in-tank regulator or a power-modulated fuel pump supplies constant pressure to the fuel line and fuel rail, regardless of intake manifold vacuum; and there is only one fuel line coming out of the tank. I've searched EcoModder.com high and low, and this is all that I could come up with: MPGuino and a Series 3 Supercharged I strongly suspect that I know the answer already, though... Might have to dust off my microcontroller skills and add this capability. |
Does having a returnless system mean that different amounts of fuel can be injected with the same length injector pulse? If it's the same amount of fuel for the same length of pulse, then I'm not understanding how the fact that the system is returnless would make a difference to the MPGuino...
In a returnless system that uses a constant-pressure fuel regulator, the amount of fuel to be injected is now also affected by the pressure differential across the fuel injector itself. In fact, it will vary as the square root of the pressure differential. Earlier systems used a fuel pressure regulator that was indexed to intake manifold vacuum, thus providing a constant pressure differential across the fuel injector. These earlier systems would reliably squirt the same amount of fuel for a given fuel injector pulse, whether at idle or at cruise or going up a hill or at WOT. Given that my fuel pressure regulator regulates to a constant 58 psig, regardless of intake manifold vacuum, and that my intake manifold vacuum could vary from 5 to 14 psig, that means that the fuel injectors could themselves see anywhere from 63 to 72 psig of differential pressure. This translates to about a 7% variation of the amount of fuel that may be delivered, for a given length injector pulse. The engine computer knows this and will compensate, but the MPGuino does not (and cannot, in base form). |
Interesting! Thanks for the explanation.
Sounds like you'll be taking a reading off the manifold pressure (along with the injector pulse) so you can emulate the ECM? Any particular reason you didn't go with an OBDII approach (OBDuino, Scangauge, etc)? |
Not sure about the OBDuino or the Scanguage, but I know for a fact that the UltraGauge cannot accurately show the effect of the ecomods I have done to the engine of the Karen-mobile. For instance, this post about initial EGR sensor modification results showed a real-world fill-up FE figure of 25.8 MPG. However, the Ultragauge only recorded a per-tank average of 23.9 MPG. This, after I had previously calibrated the Ultragauge to get its average FE reading to within 0.2 MPG of the calculated fill-up FE figure. It's very likely that it has something to do with the way that the Ultragauge estimates fuel consumption. If I am lowering intake manifold via increasing EGR opening, then the MAP sensor reading will reflect that, and the Ultragauge is likely showing that as a artificially lower fuel economy figure. The Scangauge is likely going to use some version of MAF to estimate fuel consumption. The OBDuino get_icons function actually does do this -> "formula: (3600 * MAF) / (14.7 * 730 * VSS)". The only way to really get around that, IMO, is to directly measure fuel consumption. The MPGuino is still going to provide an estimate, but it should be very accurate, compared to the estimation formulas used in OBDII instrumentation. I got a couple of MAP sensors laying about, so I can get both ambient and intake manifold pressures with little effort. The JellyBeanDriver version of the MPGuino has hardware provisions for collecting 2 different analog signals, and it should be a relatively simple matter to code in a simple square root function. |
Ford ERFS patent - first used in 1998 Ford vehicles. Varies fuel pressure according to load. 2009 Toyota RAV4 New Features - uses a mechanical fuel pressure regulator in-tank, implying a constant pressure fuel system. Your RAV4 MPGuino is accurate? |
Say that I have the MPGuino installed, as is, in the Karen-mobile. I have it tuned for highway driving. There is no compensation for the constant pressure returnless fuel system. Now, if I turn around and do a bunch of city driving, then the MPGuino will now indicate less fuel was consumed, than would actually be the case. This would be because the vehicle would be under less loading than on the highway. This would not be reliable. I might as well have just relied on the Ultragauge I have now. |
Not questioning your approach (please don't take it that way), but I am very interested in your thought process... it's an interesting problem. |
sounds like you need to modify the injector pulse reading based on a maf reading? That could take some experiment and custom mapping and a maf sensor input. Lower maf reading would mean the injector squirted more fuel for a given open time, so the code would bump up the time by some percentage of maf or something. Or some external adapter maybe, op amps and duty cycle and etc.
what would your car do if you installed a regulator that referenced manifold pressure? Would it adapt? How for off is the guino?
From what I can see, it'll be a simple matter of soldering in another wiring terminal for the two analog channels of this particular MPGuino, then running the wiring to support the two spare MAP sensors I have laying around (one for ambient pressure, and one for manifold vacuum). Since the MPGuino code (excuse me, "sketch") is written in some variant of C, it should really simple to initialize the analog channels, and convert their read-in values into pressure. Only challenge I see is to write a fairly quick square root routine - apparently, the complete math library wasn't loaded into the MPGuino in an effort to save programming space. |
Meelis |
I've compiled the major steps I will need to proceed with this project: 1. Dust off an old MicroCore11, and turn it into a simple SCI programmer (they call it an "ICSP interface" - how cute!). 2. Obtain the latest MPGuino code 3. Solder an extra set of terminals onto board 4. Construct a testing pigtail that will connect to two MAP sensors 5. Add in-car wiring 6. Modify MPGuino code to include editable parameters relating to add-on MAP sensors 7. Modify MPGuino code to interface with said sensors 8. Modify MPGuino code to utilize sensor readings |
Well, I got a little side-tracked with going through the MPGuino v0.86 code, to figure out how it all works. However, I am through it, and have figured out the likely spot to inject the pressure correction factor (the fuel injector shut-off interrupt handler), and have also figured out that the factor will likely be calculated on-the-fly in the main body of the program code. The interrupt handler simply cannot be saddled down with anything resembling a square root calculation. Having the correction factor being calculated once per display update cycle will lead to inaccuracy, but I think it'll be orders of magnitude better than having no correction factor at all.
In the course of figuring out how the code works, I've managed to shave off some 3000 compiled program bytes and some 100 lines from the code, to optimize the code somewhat to add the correction factor computing. I will go through this subforum to glean off some other interesting ideas. |
Miscellaneous MPGuino optimization note
This:
Code:
if (parms[metricIdx] == 1){ Code:
if (parms[metricIdx] == 1){ |
Notes on what I did this past night... |
Very interested in following this! Thumbs up to T Vago!
I've got a 92 Dodge Dakota that needs monitoring, and it has the Chrysler constant pressure setup. I want to build a custom MPGuino with fuel pressure monitoring. An added wrinkle... this truck also runs on wood. I start on gasoline and switch over gradually. So to shut off the gasoline I reduce the fuel pump voltage to lean out the mixture as I transition to woodgas. This lowers the fuel pressure and leans the mix, while I simultaneously ramp up the woodgas. Eventually I reach 0 pressure and no gasoline, although the injectors still fire. A stock MPGuino would be way thrown off by this. But if it could compensate for the pressure... T Vago, will the code be able to reduce the fuel usage to zero at no pressure? That would be awesome. |
OK, I read it closer, you're working off the MAP sensor.
Could the same code be converted to work with a fuel pressure sensor instead? |
^ Notes on what I did today to my MPGuino code. Also experimented in Excel about what sort of square root algorithm to use. |
^ What I have done in the past two days. Probably going to make my own "version 2" thread. (still haven't decided on a suitable square root function yet...) |
Testing my updated code revealed that rather interesting fuel consumption runaway bug that was first documented in this post by DCB. It is always interesting to see my tank fuel economy just drop from 23.6 MPG to 1.0 MPG.
Re-examined the code and did some more searching around this sub-forum, and theorized that when my car goes into DFCO, it shuts off the fuel injectors, but it still sends little pulses, like in this post by rmccomiskie. I can reliably see the above fuel consumption runaway happen on every commute so far. Hopefully, tonight, when I load in this code, it will squash this bug. Code:
ISR(INT0_vect) { // fuel injector open event handler |
One thing i did with contrast, is built-in the brightness setting into it. I.e, take the LSB 2 bits of Contrast to determine which brightness index to use. So 44 would be brightness[0], 45 is [1], 46 is [2], 47 is [3], 48 is [0]. I found that I was never ever changing the brightness, so I re-assigned the middle button to other things, and just make it dim-out a couple minutes after engine-off. I would like to see how you cleaned up the timers & buttons. I like what you did in the Inj ISRs, by directly grabbing TCNT2 and overflow_count instead of calling microseconds(). I only recently discovered that recursive microseconds bug & got rid of it after i couldn't understand why it should ever do that. I still have an older bug that's hanging my 'guino up, right near the time when the timer2 value rolls over past 0xFFFF FFFF. Unfortunately, it takes 5-7 days for the bug to trigger, so I'm still waiting to catch it. |
One thing about your injOpenStop = timer2_overflow_count | TCNT2; code: Are you using the same prescale factor=64 (TCCR2B= 1<<CS22;); If so, I believe each tick is worth 4usec, so your calculation should be multiplied by 4. (I think. I've only just started looking into timers.)
Code:
volatile uint8_t lastPINCstate = PINC; Code:
ISR(TIMER2_OVF_vect) { // system timer interrupt handler Quote:
After going through the code, I decided I just didn't need that any more. For one thing, it wasn't really returning values in true microseconds. For 16 MHz systems, it'd return values in units of (16 000 000 / 64), or 4 us, but for 20 MHz values, it't return values in units of (20 000 000 / 64), or 3.2 us. Besides that, doing the conversion was just another arithmetic operation that could have been folded into the mileage/distance/economy/time calculations. So, fuel injector pulse times, idle times, and even the system time are now measured in timer2 cycles Also, to optimize calculations involving timer2_overflow_count, I decided to have the timer2 overflow handler bump timer2_overflow_count by 256 instead of by 1. That got rid of constantly having to multiply timer2_overflow_count by 256 whenever it was desired to read the time. The timer2 overflow has been vastly expanded, to get rid of microseconds() altogether. The main loop uses timer2 to do its loop delays now, instead of having to track the time by itself. I'm thinking that this may have gotten rid of that freeze-up bug altogether. Also, function delay2() now "calls" the overflow timer to do its delays, but also I'm thinking to get rid of that, in favor of having timer2 drive the LCD output directly by using an output buffer. Code:
injOpenStop = timer2_overflow_count + TCNT2; // read current TCNT2 |
Here's how I optimized my microseconds(): Code:
typedef union { ulong ul; Quote:
I noticed that when I started to perform code optimization of the 0.86 code, it would start to just freeze up. I haven't yet figured out why, though, as I had already progressed on more-or-less re-writing the 0.86 code. That code is nice and rock-solid stable.
Are you calling your microSeconds() function in your ISRs? If you are, you might want to slightly modify your interrupt disabling mechanism a bit. Something more like: Code:
ulong microSeconds (void) Remember also that if you happen to read TCNT2, it might roll over and overflow right before you read it, thus giving a false lower value. This is why it's generally better to read the value, check for overflow condition, then read again and adjust for the overflow if the overflow condition is found to exist. All this, of course, is done while interrupts are disabled. I strongly suspect this is why the original microSeconds() function had a recursive call, to try to get around this quirky aspect of timers. |
I'll ponder the whole Read-CheckOverflow-ReadAgain thing later. I'm not sure it really makes a big difference. If it's off by 256usec (or 1024), it only affects a calculation at that moment, and it's not cumulative, so what are we really losing? There's a total of 11 clock cycles (< 0.7usec @16mhz) between cli & sei here. The original recursion code was testing against 4290560000, which is 4407296 less than FFFF FFFF. That means it would recurse, except during the last 4.4 seconds of the timer's 68 minute life cycle. I tried googling around for those numbers, but was only pointed back to the mpguino code, so it doesn't appear to be an established practice. Also, i only removed that recursion thing very, very recently, so i dont think it was preventing any freezes or resets i was having. |
For instance, say you disable interrupts inside MPGuino using cli(). Timer 2 is still merrily going on its way at 1/64th of the system clock, as it was configured. During the course of your routine, timer 2 overflows. It sets the overflow flag, but since interrupts are still disabled, your routine will continue to execute without any interruption. Once interrupts are re-enabled (via sei(), or restoring the SREG from a pre-cli() state), the timer 2 overflow interrupt will now fire. |
vago; where'd you get your fuel pressure from because everything i've read for every chrysler produced from 99 or earlier, on is suppost to be 49+/-5psi?
if your fuel pressure reg is actually getting 58+psi(you said 58psi over atmospheric so 72psi) you might want to replace/fix it; it might fix your problem from a factory service manual (4) If operating pressure is above 54.2 psi, electric fuel pump is OK, but fuel pressure regulator is defective. Replace fuel filter/fuel pressure regulator. Refer to Fuel Filter/Fuel Pressure Regulator Removal/Installation for more information. |
1 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1374501620 58 psig, or 400 kPa. Now, my truck, on the other hand, does have that 49.5 psig rating. That's good to know information - I will need to add another eeprom parameter to compensate. |
[youtube]IHs_eQlXDd8[/youtube]
The injector pressure differential correction factor code has been written, and is now in a stable version. Code testing is underway. |
WARNING - Novel Alert
Results of testing today - Partial success.
Today, on my drive to work, the calculated injector correction factor was a bit off, from what I expected, leading to lower-than-correct fuel consumption readings. However, my code was easily able to read and process MAP sensor readings for each individual fuel injector event. Given that said events can occur from once every 150 ms to once every 19 ms, this represents a very significant capability. Equation 1 below is used to correct the fuel injector pulse length reading for a returnless fuel system-equipped vehicle, when said vehicle uses a constant-pressure fuel pressure regulator. (1) - F = sqrt( P(diff inj) / P(fuel pressure regulator) ) However, the equation for determining the pressure differential across the fuel injector, (2) - P(diff inj) = P(fuel system) - P(intake) has some complication associated with it. In particular, P(fuel pressure regulator) is a gauge pressure reading, while P(intake) is an absolute pressure. Or, (3) - P(fuel system) = P(baro) + P(fuel pressure regulator) Where P(fuel pressure regulator) is the rated fuel pressure of my fuel pressure regulator, and p(baro) is the absolute atmospheric pressure. Thus, equation 2 above turns into: (4) - p(diff inj) = P(fuel pressure regulator) + P(baro) - P(intake) Right now, my P(baro) estimator works by setting P(baro) to P(intake) when it senses that both the engine is turned off, and the vehicle is not moving. Ideally, this would give an accurate P(baro) right before the engine is turned on. However, in real life, this isn't always the case. The MPGuino hardware is always turned on, but the engine computer is sometimes shut off. When this happens, the power to the MAP sensor goes to 0 VDC, so the MAP sensor output itself goes to 0 VDC. This is what happened today. I noticed that my estimated P(baro) was effectively at zero psi. This will (and did, of course) throw off the correction factor, rendering it useless for its intended purpose. Clearly, I will need to do something about that. Now, I could recode the P(baro) estimator, but it would cause my code to grow more than it already is. As of right now, the code sits at 19640 bytes. Or, I could retain the existing code, and simply wait for a few seconds or so, after turning the ignition key to On, and before starting the engine. That would certainly give me an accurate P(baro). However, that would require that the driver wait before starting the engine every single time. Maybe the average MPGuino user would be this anal... I don't know. However, I don't want to depend on that. Just had this thought - even if I did get an accurate P(baro) right before starting the engine, that P(baro) would only be accurate for a little while. Weather changes, elevation changes, and temperature changes all affect P(baro). My engine computer gets around this by estimating P(baro) based on throttle position, the MAP sensor, engine speed, and a lookup table. However, to implement something like that into my code would require both using the remaining analog input, and a calibration to generate a suitable lookup table. That could prove to be very challenging. Were I to add a separate pressure sensor dedicated to solely measuring atmospheric pressure, that would certainly get rid of any costy estimation code, and any undue expectation on the part of the driver, but it would do so at the cost of using up the remaining analog input. This might not be a problem, but then again, it might be. For instance, I've read in this forum that other users saw how system voltage changes cause changes in injector reaction time, and went about coding to compensate for that. Well, that needs an analog input to be able to measure system voltage. If that input were instead used for barometric pressure, one would have to assume a more-or-less constant system voltage (which the base MPGuino code does, BTW). Not to mention that a separate MAP sensor costs in the range of $40 or so. I will probably end up going with adding a separate MAP sensor that is dedicated as a barometric pressure sensor. It will, of course, eat up that remaining analog input. However, it might be beneficial to members like KY Metro, who are looking to add a fuel pressure sensor due to how they operate their fuel pump. As long as the fuel pressure sensor would also read absolute pressures, this would not pose any problem with my code. |
If you only need one more analog pin, you could move the VSS over to your newly-free pin3.
The buttons are a big waste of analog inputs. I plan to add resistors to mine, and have all 3 (plus a 4th) share a single pin. Also, if you happen to use a TQFP atmega, there are 2 extra analog inputs available: A6 and A7. |
But try it yourself. José Rodrigues |
That's easy for you to say, Jose, with your 16 Analog & 53 Digital I/O =)
I am going to try it though. |
