Old 10-17-2015, 01:46 AM   #1 (permalink)
aeR!R!R!o
Reduce! Reuse! Recycle! I have the idea of using an old bicycle inner tube as a retractable backing for a front air dam under the bumper (I think one of the new Porsche 911's have something like this), the thinking behind this is having the capability of retracting a front air dam for entering parking lots with their notoriously goofy transitions/approach angles and at low speeds or on shabby roads. I have yet to sort out the details, but it would essentially be a plastic air dam glued to an inner tube with an air line running to a suction/pump unit. I was thinking it would be good for retractable skirts as well, this is among the list of bats**t ideas I have yet to test but I figure it may have some moxy and is worth a go, if you care to try this idea or have criticisms lemmeknow.
Old 10-17-2015, 03:20 PM   #2 (permalink)
active aero
This will give you your areas which are off-limits to 'fixed' body parts
After that,you can use any technology that works for you.
Volvo actually put this 'active',electrically-operated airdam on production cars.
Haven't seen rocker panels done yet.
BamZipPow (10-17-2015)
Old 10-17-2015, 05:56 PM   #3 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
I know the Mitsubishi 3000GT VR4 had the electronic activated air dam from 1991-93. It was dropped fer later years.
I think the issues with the air dam was the motor gitting corroded and not activating.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (10-19-2015)
Old 10-17-2015, 09:57 PM   #4 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Thanks for sharing your ideas Green Squirrel.
BTW,
I made an airdam a few years ago that had a heavy duty spring hinge behind it. As I came up to a speed bump, the airdam would fold back and then spring back into place afterwards.
Here is an example of the hinge :
I decided against it because the spoiler had too much frontal area.
The Following User Says Thank You to Cd For This Useful Post:
Old 10-17-2015, 10:38 PM   #5 (permalink)
It would need a means of moving air two ways, and a pivot to gain leverage against.
