02-05-2015, 03:24 AM
Fiesta - '06 Ford Fiesta 1.4 Ambiante 90 day: 45.9 mpg (US) Dakar - '03 BMW f650 GS Dakar (retired) Tucson - '07 Hyundai Tucson 2.0 GLS 90 day: 32.67 mpg (US)
Aero flaps continued, advice needed
02-05-2015, 09:45 AM
Aero Deshi
The way I read your descriptions it seems to conflict with your drawing.
At any rate, here are the facts as I see them, Option 1 on the EEE Dwg with the device on the rearward part of the light is 10 times more effective than Option 2 of the same drawing.
Sealing the gap would gain you such an insignificant result, you'd need a super computer, advanced wind tunnel, and a team of Formula 1 aerodynamics engineers to figure out the difference in Cd.
The whole idea is to get the air to make a clean break there at the back of the car so the air just flows smoothly instead of flapping back and forth in a wavy oscillation. So putting it forward would allow the air to try and reattach gaining you nothing or possibly hurting the Cd.
That said, the gain here would be very small even if you execute the shape perfectly due to it being such a small inefficiency that you're trying to correct.
The air in the "Boundary layer" within a few centimeters of the skin of the car is not the source of drag on your vehicle. It is the air out to 10 feet to the front, top and sides and 100's of feet behind being displaced by your car as you drive through it that is creating the drag. The drag comes from the energy required to move that huge volume of air, the more it moves, and the more of it that moves, the more energy it takes, and the less efficient it is. The most efficient shapes make the air move the least amount and it goes back to being calm within the shortest period of time.
There are papers out there that show how the rear edge radius of the vehicle affects the Cd. Very large and very small radius corners do well, there is a "Death Zone" radius of like 5 to 10 centimeters as I recall that really create a large drag. I'll try to find one the papers and post it later.
Hope that makes sense.
The Following 5 Users Say Thank You to ChazInMT For This Useful Post:
02-05-2015, 01:42 PM
Make kerf cuts in the wood piece to help it conform to the body contour. Or, make a female mold of the wood piece, and then make flexible foam duplicates of the wood piece's shape by using Gorilla Glue, which expands and foams while curing.
BTW, what sort of aero improvement in overall CD do you reasonably expect?
The Following User Says Thank You to Otto For This Useful Post:
02-05-2015, 07:30 PM
https://en.wikipedia.org/wiki/Gurney_flap
"Everything should be made as simple as possible, but not simpler." - Albert Einstein
02-06-2015, 01:43 AM
02-06-2015, 01:14 PM
The A-pillar fillet is something I should probably make for my car, for wind noise.
What I am suggesting is a 'trip strip' located at the short leg of your Option A. Since some of it would be on the taillight clear plastic might be a better material. You could use your suggested method below the taillight. At the bumper it would be a 'skeg' that could integrate into a difusser.
02-06-2015, 01:25 PM
herp derp Apprentice
Id be very intrested in that paper too, as I think every "edge" ... or lack of an edge on the rear of my car is in the death zone
02-06-2015, 10:57 PM
I wonder what we'd be tinkering with if we lived on the moon.
02-07-2015, 03:46 AM
#9 (permalink)
Ultimate Fail
I vote Option 1.
I'm an armchair aero geek, and know nothing of aerodynamics, but I would think that Option 1 might be a fraction of a percent better.
I base this guess on the fact that every trip strip / air ramp that I have seen, is located at least two inches within the area of the car that has a radiused edge.
Some good examples are the pictures you posted. If you notice, the body panel begins to curve a couple of inches before the trip strip.
However, there are some exceptions, such as the air ramp on the Ford Focus tailights :
A curious thing abou the Focus is the fact that the air ramp is there on a section of the light, but directly below it is a massive round edge to the bumper and area above the air ramp.
02-07-2015, 04:03 AM
#10 (permalink)
Originally Posted by Cd
I I base this guess on the fact that every trip strip / air ramp that I have seen, is located at least two inches within the area of the car that has a radiused edge.
Cruze hatch has them located a long way inboard (on the window):
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
