Old 11-17-2016, 04:51 PM   #1 (permalink)
24 Grom - '24 Honda Grom
90 day: 121.34 mpg (US)
Wheel Spat Help
Ok I'm wanting to add spats to the front and rear wheels. I'm seeing different ones which is making it confusing. It looks like they just go in front of the wheel.
Ok so onto the questions.
Is there a stand off distance they need to be from the wheel?
How low do they need to be? look at #1
How wide do they need to be? (guessing the width of the tire)
Do they need to be straight up and down? (I would think being at an angle to be more aerodynamic towards the wheel would be better, but i'm no expert)
Picture below
which would be better 1 or 2
The Following User Says Thank You to compdrag For This Useful Post:
aerohead (11-19-2016)
Old 11-17-2016, 09:19 PM   #2 (permalink)
The perfect is the enemy of the good-enough:
http://ecomodder.com/forum/showthrea...tml#post526976
Site search isn't working for me so I had to use Google to find this thread from 2010:
http://ecomodder.com/forum/showthread.php/show-me-your-wheel-spats-13669.html
Also:
http://www.toyotanation.com/forum/104-5th-6th-generation-2002-2006-2007-2011/834553-deflector-before-rear-wheels.html
MetroMPG (11-21-2016)
Old 11-19-2016, 01:36 PM   #3 (permalink)
design
Picture below
I believe that this sort of thing is not in the category of one-size-fits-all.It's going to be different for every make of vehicle.And you could spend $100,000 in a wind tunnel to optimize the design for just 1-car.
I'd recommend Goro Tamai's book,'The Leading Edge' for an in depth discussion on wheel drag.
Old 11-19-2016, 05:53 PM   #4 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Not exactly tested, but I went big with my front wheel spats. I wanted all of the air that would normally hit the tire directed around to the outside.
No rear spats, I have skirts along the sides.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
