Aero photos from El Mirage SCTA finals
18 Attachment(s)
Just a handful of pics arranged in an order meant to help you see aero features. Several pics are of the dust trailing wakes of the cars I photographed before their runs.
Here is the wake of the streamliner motorcycle featured in the attached pics: http://ecomodder.com/forum/attachmen...2&d=1384151834 Here is the wake of a roadster: http://ecomodder.com/forum/attachmen...3&d=1384151876 Here is the wake of the yellow Austin van featured in the attached pics: http://ecomodder.com/forum/attachmen...4&d=1384151892 All images taken from almost the same distance, give or take a dozen yards or so... |
Great pics! Thanks for sharing. Any additional info on the vehicles in the pics?
Can't really tell much from the dust wake if vehicles speed is not consistant, can we ?
Right.
And for the weight thing, I guess the test would be to drive a fully loaded semi and an unloaded one side by side & compare their dust trails. I guess I'm also thinking about the tracks they leave in the dirt..... those big duals plow up a lot of dirt when they roll over it with all that weight. To me, that has to translate to much more dust in the wake. Compare it to a motorcycle going the same speed, maybe. Of course, you'll say the motorcycle has a fraction of the frontal area, too..... Hmmmm - - can we somehow load 10 tons onto a motorcycle????? or reduce the weight of said semi truck to 1000 lbs???? Maybe a strict weight vs. frontal area test would be difficult..... |
photos
The photos are great!
If wind tunnels had test sections this long and you could photograph the test vehicle at a far enough distance we'd see the same thing if smoke was introduced into the wake. This illustrates the magnitude of the wake and its relationship to fuel economy,and how an internal combustion 1987 Sunraycer would achieve 300 mpg. Hucho could use these sorts of images in his books. Thanks mucho! I would have liked to have been there.:) |
speed
The magnitude of the energy is following the square/cube relationship,so sure,the wake will be more dramatic if a Bugatti Veyron or Mike Cook's Thunderbird blows by at over 260 mph. The lake bed dust is already pulverized.And sure,if you've seen video of the Lunar Rover you know that the tires will sling dust even in a vacuum.But it is the low base pressure of the turbulent wake which allows the dust to migrate far afield of the tires 'toss' area. Ritchie Ginther's first rear spoiler was designed to prevent this 'dust' from moving forward into the cockpit of his Ferrari and killing him.It was only an accident that it also spoiled rear lift. |
