Old 03-18-2009, 11:50 PM   #1 (permalink)
chilimac02's Avatar
Kammback on an Explorer?
Would a Kammaback work on an SUV? It seems like a bit of a stretch...
Old 03-19-2009, 12:07 AM   #2 (permalink)
Explorer Kammback
It seems it should help, based on what the people on here have done with minivans. But to start with, you should have a 2WD rather than 4WD, 2-door rather than the heavier 4-door, and the 4.0, not the 5.0 engine for the best FE.
I don't know which years were the lightest weight.
Ray Mac
Old 03-19-2009, 01:32 PM   #3 (permalink)
90 day: 51.82 mpg (US)
Sure it would work.
But don't expect a miraculous change - something on the order of a few percent improvement from a small to moderate extension.
Old 03-20-2009, 02:47 PM   #4 (permalink)
Kammed Explorer
SUVs pose conflicting challenges for streamlining.While their huge frontal areas and large drag coefficients would benefit the most from streamlining,their relatively straight sides and roofline and full-frontal-area-wake require enormous extension of the body,with curved taper to both roofline and body sides to realize any real benefit.
A friend has a Toyota Highlander,and we're considering a receiver-hitch,cargo-box-based boat-tail extension,to push his highway mpg from 28,to 32,which will require about 30-inches of additional length,psychologically quite a hurdle!
I'm pretty confident that a boat-tail is one of the few things that would actually help your Explorer,you'd just have to weigh out the reality of additional length.
Old 10-08-2012, 10:22 AM   #5 (permalink)
the red car - '94 Ford Aspire Four Door
90 day: 43.46 mpg (US)
Adventure Wagon - '01 Kia Sportage EX 2wd 5 door
90 day: 23.92 mpg (US)
Any updates? I have a 2wd KIA Sportage that should be squeezing more than 22 mpg with It's 2.0. I cut the front springs and installed a slanted grill block and my best tank is 25 mpg. My next trick will be an air dam and partial belly pan. I also want to relocate the spare tire and remove the swinging rack. The only way to help my city miles will be to reduce the 2 ton weight as much as feasible and the wheels might be the best place to start.
Subaru Outback Kammback Experiment brucey Aerodynamics 18 11-16-2014 02:45 AM
Project: making a permanent Metro Kammback extension MetroMPG Aerodynamics 256 09-11-2013 04:22 PM
Accordion Kammback for big rigs ? Cd Aerodynamics 36 02-27-2012 05:03 AM
Minivan Kardboard Kammback boosts MPG +3.7% (6.6%, counting roof rack delete) MetroMPG Aerodynamics 31 05-20-2010 12:23 PM
Kammback design trikkonceptz Aerodynamics 1 05-07-2008 06:07 PM
