Old 07-28-2009, 02:06 PM   This thread is in the EcoModder Project Library | #1 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Stainless Kammback for Previa.
Just finished this today. At this point It's still a roof and sides extension but I'm adding bigger panels soon. I can't wait to try it out. I have to find some rubber moulding for the leading edge on the sides where it touches the paint.
The pieces are all totally detachable and no holes were drilled into the body. I used existing bolt holes and bent stainless brackets to attach everything to the back door. I tried to get around 10 degrees slope and will gently curve the panels to get optimum taper. I plan to make the panel over the rear window plexiglas so I will be able to see and do tuft testing easily.
Cutting out the side panels:
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 07-28-2009, 02:39 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
orange4boy -
Wow, I love 100% reversible mods. You're my hero!
CarloSW2
American Solar Energy Society
Old 07-28-2009, 03:27 PM   #3 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
Thats a very nice bit of craftsmanship. Well done. Does it save much fuel? Improve stability?
ollie
Old 07-28-2009, 03:28 PM   #4 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
Here are some more of the brackets.
It was a PITA to get the stainless to bend in just the right shape but nothing a good hammer couldn't sort out.
I'm hoping I won't get any flutter at speed. There is a small gap which will go away when I find a moulding. In the meantime, some foam draft seal should do the trick.
Ollie,
I haven't had a chance to test it yet. Will do soon but probably no a-b-a. At least not yet.
Old 07-28-2009, 03:45 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
orange4boy -
Ollie,
I was gonna mention the gap later on, but I was betting you're already on it, and you are.
CarloSW2
Old 07-28-2009, 05:25 PM   #6 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
Awesome job!
Cant wait for the results
Past Present Future?
Old 07-29-2009, 04:53 AM   #7 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
Took the van to town today. Too soon for data but coast down on a regular run was about 5-10kph higher than before.
I did register a lot more LOOKS than before. Does that count for anything? I preached the Ecomodder gospel to a few interested people too.
Old 07-29-2009, 05:02 AM   #8 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
Fantastic work
I'm so ashamed with my uglyback...
Please, keep us informed with your feelings and your improvements
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 07-30-2009, 01:13 AM   #9 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
On the road today with the new extensions. Coast down is definitely better. I got up to 120kph in a spot where I usually only hit about 105Kph. Mileage stayed the same but I was using A/C today. The egg is a greenhouse crossed with a magnifying glass. Where can I get those mesh seat backs in Vnacouver?
I can't wait to add the kamm panels. Wait, what am I doing here typing when I could be modding?
Old 07-30-2009, 02:16 AM   #10 (permalink)
Grasshopper
dont forget to get full side shots
Project: making a permanent Metro Kammback extension MetroMPG Aerodynamics 256 09-11-2013 04:22 PM
Accordion Kammback for big rigs ? Cd Aerodynamics 36 02-27-2012 05:03 AM
Minivan Kardboard Kammback boosts MPG +3.7% (6.6%, counting roof rack delete) MetroMPG Aerodynamics 31 05-20-2010 12:23 PM
Sedan Kammback? KJSatz Aerodynamics 10 09-28-2009 04:58 AM
Non-invasive mounting for kammback wagonman76 Aerodynamics 4 03-24-2009 06:15 PM
