Old 12-03-2009, 03:37 PM   #11 (permalink)
ncs
RockMagnet - '04 Subaru Impreza wagon WRX
90 day: 26.16 mpg (US)
The 7th gen Celica was only offered without a spoiler for one year. The spoiler became standard equipment after high speed stability problems were found without it. The spoiler blocks half the view out the rear windows.
VW also added a spoiler to the current Beetle for similar stability reasons.
In both cases, the handling problems were only apparent at speeds above 75mph. Wind speeds we'd only legally see driving into a head wind.
Here's some second or third hand info on two modern cars.
euro spec evo IX and 06 STI
The red arrow represents lift at air flow of 40m/s (around 144km/h or ~90mph), the blue – at 55m/s (approximately 200km/h or 124mph). The lift is measured in newtons. One newton equals roughly 0.22 lbs.
On my car, I removed the hood scoop and the steering became slightly heavier.
ID:	4928   Click image for larger version
ID:	4929   Click image for larger version
ID:	4930   Click image for larger version
ID:	4931   Click image for larger version
ID:	4933   Click image for larger version
Old 12-03-2009, 04:27 PM   #12 (permalink)
Stickers - '91 Ford Tempo GL
Send a message via AIM to Hermie Send a message via MSN to Hermie Send a message via Yahoo to Hermie
From another thread: http://ecomodder.com/forum/showthrea...tml#post120492
The Audi TT in question was notorious for high speed lift-off snap oversteer due to the style-over-function design. After that incident (not the only one), the optional rear spoiler was installed on all of them by the factory.
My 1983 Subaru GL sedan was a similar style car to the Tempo with a likely comparable drag coefficient. I had few stability issues until it was topped out at "P" (the P in MPH at the bottom of the 85 mph speedometer), which worked out to be around 110 going by the tachometer. At that point, it would move around a little in crosswinds, but could still keep in a lane sawing the wheel like a '50's movie racecar driver. Where it bothered me was on on-ramps at speeds over 80, with significant understeer, so I added a front airdam. Got slightly better mileage which was probably within a margin of error, but it did add straightline stability and cured the understeer (at least the lift-induced understeer). What it also did (besides scrape the occasional driveway when I forgot to enter at an angle) was increase oversteer to a level that was fun in the dry and a little hairy in the wet. A tree fell on it while I was driving down the street, so I never got to put an adjustable rear spoiler on the trunk.
Other members here have had direct experience in the negative aspects of lift.
That's because you reduced front-end lift from reducing the pressure buildup under the hood.
Also, the "apparent" dangers of lift can be seen even at slower speeds during sudden manuvers- eg., swerving to avoid an accident.
Old 12-03-2009, 04:48 PM   #13 (permalink)
Originally Posted by Hermie View Post
Probably closer to 700. I don't think the rear wheels have just 300 pounds each (which they would with your numbers)... That would make it EXTREMELY unbalanced.
You have a 2000 pound Tempo that drives itself down the road empty? Tell me more about that Mr. Real World.
Old 12-03-2009, 05:01 PM   #14 (permalink)
The early Datsun Z cars had so much lift, at 100 MPH the front wheels looked the same as they did when you pulled the engine out of the car.
Air dams were the solution.
regards
Mech
Old 12-03-2009, 05:05 PM   #15 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Jeep Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Geo Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Plymouth Grand Voyager SE
Ninja - '89 Geo Tracker
90 day: 30.27 mpg (US)
This old data is more important than we might think. consider "factory fixes" for aero issues goes out the window with our cars when we start messing around with the aero IE kambacks air dams grill blocks boat tails skirts all ALTER the aero of the car and may introduce some of the problems the OEM designed out of the cars :-)
Just something to think about.
Old 12-03-2009, 05:39 PM   #16 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
In all honesty, at the speeds we drive, it doesn't matter. If it was increasing lift a lot, it wouldn't help gas mileage.
Old 12-03-2009, 08:34 PM   #17 (permalink)
Tempos weigh about 2600 pounds. If they had 1000 on each front wheel, as you said, that would only leave 300 per rear wheel.
Consider that the Tempo front wheels probably have 1000 lbs on em each.
Your numbers are off, and learn how to read.
Old 12-03-2009, 08:59 PM   #18 (permalink)
Tempos weigh about 2500 lbs empty. Add two guys in the front seats at 200+ lbs each and 15 gallons of gas at about 90 pounds and you have a 3000 lb unit for a typical load. Then know that 2/3 the weight of Tempos is on the front wheels and you have 1000 lbs on each front wheel, and 500 lbs on each back wheel.
I've been a gearhead since before you were swimming around in your Dad's shorts, ya punk. Put your car on a scale and get back to us.
Old 12-03-2009, 09:19 PM   #19 (permalink)
Hi Hermie,
Can you explain your apparent fixation on lift, please? When has it actually affected you?
Old 12-03-2009, 09:23 PM   #20 (permalink)
Hi Hermie,
The dynamics of the flow of the air particles may produce an effect at 300 miles and hour that would create a force upon which would lift the tires off of the ground enough to cause adverse handling when trying to swerve/take evasive action on a rain soaked hill.
But seriously, tell us why.
Aerodynamic Heavy-Duty Truck Trailer Cuts Fuel Consumption and Emissions By Up to 15% SVOboy Aerodynamics 11 12-27-2011 07:18 AM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
Modern Rolls Royce Phantom vs Aerodynamic Coupe Unheard Aerodynamics 2 06-19-2009 10:19 PM
How to create lift using the underside of your car trikkonceptz Aerodynamics 24 03-13-2009 11:10 AM
[article] 5 Real DIY Aerodynamic Mods Detroit Can Add for MPGs in '09 SVOboy Aerodynamics 15 07-01-2008 01:57 PM
