Aerodynamic mods on the "Tank"
So since i've gotten the car i've been slowly improving my fuel economy but i want more
Deleting the rear piping after the stock muffler and putting a turndown saved 10 pounds :D So now it's only 4490 instead of 4500 pounds but i still have horrible aerodynamics so i need a few ideas to help this I'm already planning on lowering my El Camino and putting a tonneau cover on it so those are automatic mods. Sorry i'm not doing flat wheel covers I would put skirts if i could find them for my year el camino though. Anyone have any more suggestions? I want to do a flat underbelly but don't know how that would work with this car |
Why the exhaust mod? Cutting the piping and letting the exhaust out earlier could allow more fumes into the cabin, killing you with carbon monoxide.
For that matter, give it VTEC. |
I've actually got a spare EcoTec motor that needs a timing chain and a head gasket...
I doubt you will find a manufactured skirt fer the El Camino. Yer better off fabbing something on yer own. ;)
How much effort/money/time you looking to put into this as a project? Simple things could be just grill block. Start out basic and work from there...unless yer paying someone else to do it fer you... ;) |
and if you look in the garage you'll see i'm planning on spening ALOT on this car it's my first car so i'm keeping it forever my plans are a 800 HP duramax that gets over 30 MPG freeway.. should be fairly easy with this car |
Regarding aero, take a piece of rope that can be easily seen, tie it to your front bumper, up and over the highest point of your cab, and down to your back bumper over the tailgate, then snap a digi of it. Upload the pic here, then check the angle of the string in the pic compared to the ground. I'm fairly certain your cab/tailgate angle will be sufficient to just add a frame and some sheets of coroplast for an aero-cap without too much thought invested. Might be good for a decent gain. :thumbup: (Try to test it somewhat scientifically, though...) |
Yeah I'll try that I had a flush mounted campershell on it but i prefer the look without it |
