Old 10-01-2012, 03:49 PM   #11 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
I like your idea, but I would not slant the bumper.
At the speeds necessary for MPG, trucks have plenty of front end downforce. A slated bumper would add downforce and generate drag. Air has weight and "making your hole in the air" by pushing it up over the vehicle requires energy. Pushing it around the vehicle requires energy too, but not as much as lifting the mass of air.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following User Says Thank You to Big Dave For This Useful Post:
aardvarcus (10-01-2012)
Old 10-01-2012, 04:50 PM   #12 (permalink)
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Thank you for your reply. I only was going to slant it to make it a little closer to the template in all dimensions, but I see your point. If I leave the bottom bumper flat up and down, that would direct most of the air striking it to the sides. It is hard to tell from the drawing, but the bumper will curve to match a fairly blunt template side to side.
That leaves the grill block directing all it’s air up and over, and the light covers would be doing a mix of up and over and off to the sides. Should I be trying to make any of those pieces direct the air differently?
Old 10-02-2012, 09:18 PM   #13 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
nice look and should serve both requirements
Old 10-03-2012, 10:02 PM   #14 (permalink)
At some point I may be making a curved front bumper for one of my vehicles.
My thought was to cut 1/4" plywood to the height of the bumper and then laminate strips with water-proof glue onto a form until it's ~1" thick. Or two, each 1/2-3/4" thick with a shallower curve behind a deeper one with the ends pinned together. It would be like a giant elliptical spring.
It would be less complex than this:
