Old 02-06-2008, 05:41 PM   #1 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Aerodynamics Seminar # 7 - by Phil Knox
This post was originally written by Phil Knox (aerohead), and it first appeared on the MaxMPG group. Phil has done a lot of work educating the masses about the critical role aerodynamics play in efficiency, and has spurred many in the DIY crowd to take matters into their own hands.
This is the seventh in a series which I'm reproducing here with permission.
Here's a formula that will allow you to estimate the horsepower necessary at the drivewheel to overcome your tires rolling resistance (power absorption).
The formula is for radial tires only,and is for 70-degrees F,smooth road,dry road, proper inflation pressure.
Horsepower HP= V/375 times[0.01184 W + 0.000353(V-66) W].
Velocity V is in miles per hour, Weight W is in pounds.
If your speed is below 66-mph,then the second term within the parenthesis falls out.
Again,to get flywheel power,take your result and divide by 0.95. This yields Bhp the engine or electric motor must provide to the powertrain,at 95% mechanical efficiency for the powertrain.
Old 02-06-2008, 07:32 PM   #2 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
Cool
BTW, I did read your PM - I will be doing a mega post within a few days
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 02-06-2008, 11:09 PM   #3 (permalink)
Excellent! Looking forward to it.
Aerodynamics Seminar #2 - by Phil Knox MetroMPG Aerodynamics 2 05-10-2013 05:34 PM
Aerodynamics Seminar # 6 - by Phil Knox MetroMPG Aerodynamics 24 09-08-2012 11:18 PM
Aerodynamics Seminar #1 - by Phil Knox MetroMPG Aerodynamics 7 08-08-2012 06:00 PM
Aerodynamics Seminar # 5 - by Phil Knox MetroMPG Aerodynamics 4 01-29-2008 01:41 PM
Aerodynamics Seminar # 4 - by Phil Knox MetroMPG Aerodynamics 0 01-28-2008 08:36 PM
