Old 06-11-2022, 03:45 PM   #1 (permalink)
Prpane as a MPG Booster
So a while back (during the last gas crises) along with testing HHO…(did not work)
The idea of running propane as a booster came up.
The claim was adding some propane could give you a 20 to even 40% MPG boost.
The problem then was I was looking for a way to run a company SELLING MPG systems and to do so they would have been required to buy the propane for a car at a propane for cars station witch with the much higher cost meant no savings. You ended up with the same cost per mile.
Plus you out say a 1K for the set up.
But now with gasoline prices at over $5.50. and no real hope they will ever come back down, propane might be a better idea.
So the only thread on this was done in 2008.
So is it a good idea nowadays?? If so data, and any how to add a system to say Ford Crown Vics etc??
Rich
The Following User Says Thank You to racprops For This Useful Post:
pgfpro (06-11-2022)
Old 06-11-2022, 03:48 PM   #2 (permalink)
Damn cannot edit title, missed the "o" in propane...mods please fix if you can.
Cannot even delete post to do a do over.
Rich
Old 06-11-2022, 06:17 PM   #3 (permalink)
LE Camry - '03 toyota camry LE
90 day: 32.63 mpg (US)
Obviously you can set an engine up to run on propane
To use it as a booster or additional fuel you're going to have to have full access to the engine control parameters. Otherwise you are just going to add the same amount of fuel AND the propane
Too much junk to list. From a 10mpg caddy limo to a 5 speed Saturn
Old 06-11-2022, 06:48 PM   #4 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
The O2 sensor should be able to compensate pretty well for as much as 15-20% offset in fueling. If you can monitor your fuel trims by OBD to make sure you're not exceeding what the ECU can compensate for, it would probably work. Propane has greater resistance to knock, which is good. A quick search suggests flame speed is significantly higher (I wasn't confident about the exact numbers I was finding), which is also good, but with a caveat - the ignition timing required for propane would be different. Specifically, an engine would need to have its ignition timing retarded significantly, or it would actually run worse. If at any point the ratio of propane to gasoline changes, your ignition requirements will also change. Multifuel systems are very much a moving target and you'll probably spend over $1000 in dyno time getting it dialed in across the entire map, not to mention the cost of the engine management.
My question would be, at what cost can you fill a tank of propane? A standard 20lb tank has about the same energy content as 3.5 gallons of gasoline, or $15.40 worth in Minnesota at the time I'm writing this.
Isaac Zachary (06-13-2022)
Old 06-11-2022, 09:08 PM   #5 (permalink)
I can.
"Propane has greater resistance to knock, which is good."
That can be a help to stop knocking in engine.
"A quick search suggests flame speed is significantly higher (I wasn't confident about the exact numbers I was finding), which is also good, but with a caveat - the ignition timing required for propane would be different."
Even mixing it in WITH gasoline?? By its self only yes.
"Specifically, an engine would need to have its ignition timing retarded significantly, or it would actually run worse. If at any point the ratio of propane to gasoline changes, your ignition requirements will also change. Multifuel systems are very much a moving target and you'll probably spend over $1000 in dyno time getting it dialed in across the entire map, not to mention the cost of the engine management."
Will need to test that.
I feel the main cost is a controller system to control the feeding of the propane.
"My question would be, at what cost can you fill a tank of propane? A standard 20lb tank has about the same energy content as 3.5 gallons of gasoline, or $15.40 worth in Minnesota at the time I'm writing this."
The question remaining is how much propane will it take to get that boost?? Back in the day it was said one 20 pound bottle of propane was good for a 19 gallon tank of gas.
So 19Gal @$5.60=$106.40 less 20%= $85.12 + $15.40= $100.52
OK that kills that.
NEVER MIND....
Rich
Old 06-11-2022, 10:08 PM   #6 (permalink)
What's fascinating to me is that the price per unit energy is actually pretty close right now. All else equal, propane is probably a superior fuel. To my understanding it burns cleaner, and if an engine is designed to run on it specifically (higher compression, geometry optimized for faster burn) it would be more efficient. But, I don't see it being a game changer for an engine retrofitted for it.
Old 06-12-2022, 04:01 AM   #7 (permalink)
Interesting: Seems it will not cause enough improvement to be even worth the trouble.
I believe I came up with the same answer last time.
My idea of a double overdrive still seems the best, but my research shows it will only work with a engine that has plenty of low RPM torque, other wise you end up lugging the engine.
That and a lean burn cruising setting which also is said to give 5+ MPG.
Rich
Old 06-12-2022, 09:18 AM   #8 (permalink)
Propane as an enhancement doesn't make much sense for a gasser, while there were some folks resorting to it on Diesels. As propane is outlawed as a motor fuel in my country, even though it's allowed for forklifts, I have already seen some big rigs using CNG enhancement for both mileage and emissions, decreasing the usage of DEF noticeably too.
When it comes to spark-ignition, propane is not so bad at all, but I'd rather take a look at some of those newer liquid-phase injection systems, instead of the vapour-phase setup which is still more usual. But neither propane or CNG are worth as MPG boosters on a gasser, yet under some circumstances while being used instead of gasoline at least CNG may be cost-effective. Too many people resort to an excessively lean AFR with CNG in my country, as it has anti-knock properties even better than ethanol, to the extent such an excessively lean AFR could eventually lead to an overheating, not to mention a performance loss. A proper AFR, even though the cost-per-mile advantage of CNG would go a little down, wouldn't cause much of a performance loss and decrease the likelihood of an overheating.
Old 06-13-2022, 09:50 AM   #9 (permalink)
Ruint Taco - '19 Toyota Tacoma SR Double Cab
90 day: 23.76 mpg (US)
I posted here before about this. It definatly can be done pretty simply
https://ecomodder.com/forum/showthre...ars-39664.html
Old 06-15-2022, 12:53 PM   #10 (permalink)
Spark - '14 Chevrolet Spark Ls
90 day: 38.44 mpg (US)
Squad cars in Wisconsin run off gas / propane , you can purchase the retired cars with the systems intact.
The Following User Says Thank You to Tmugz88 For This Useful Post:
Ecky (06-21-2022)
