Aftermarket Cruise Control, AKA Hand Throttle.
I'd like to thank you all for coming on this suspicious occasion..... May I present my very first mod!
Disclaimer: Since they seem to be releasing newer, more updated idiots every day, this mod cannot be made idiot-proof. Therefore, this is presented as documentation of a mod I have done. If you do it yourself and it causes you to crash your car and you break your legs don't come running after me! The victim in question is a 95 Corolla with no cruise control. A week from today I will be traveling from Texas to Missouri and Michigan. Since I have made this trip before in this car, my right leg was already beginning to cramp in anticipation! Step one: I found a bike from which I removed a gear shifter. (and other misc parts which were used) http://ecomodder.com/forum/member-hu...donor-bike.jpg 2: I removed console and panel under steering wheel (and whatever else needed to be removed to remove those!) http://ecomodder.com/forum/member-hu...-car-parts.jpg 3: Mounted the shifter to the shifter :D http://ecomodder.com/forum/member-hu...st-fitting.jpg 4: What could be the purpose of that bracket next to the shifter, I hear you ask? Why thats the perfect location to mount a toggle switch which will eventually become a kill/start switch (as soon as I get a round toit) http://ecomodder.com/forum/member-hu...ook-switch.jpg 5: Routed the cable from the shifter towards the gas pedal: taped it securely to the shifter and various places along the way, also added tape in potential wear areas. http://ecomodder.com/forum/member-hu...le-routing.jpg 6: Found a mounting point under the steering wheel near the gas pedal http://ecomodder.com/forum/member-hu...ing-column.jpg 7: Created a bracket to which the cable will mount, placing the cable relatively square on with the gas pedal, since the cable will be pulling on the upper end of the pedal. Also, created an attachment point on the pedal so I can adjust the slack in the cable. http://ecomodder.com/forum/member-hu...ion-view-2.jpg 8: Once it's all hooked up try it with the engine off: make sure the pedal goes back up when the hand throttle is returned to the "off" position. 9: reinstalled interior. Pondered origin of excess screws (seen in console) :D http://ecomodder.com/forum/member-hu...ed-shifter.jpg 10: Test in driveway and played with it until it worked right. At first cable didn't have enough slack, and engine ran @ 2000rpm with throttle off. 2nd test with more slack: after using hand throttle engine didn't return completely to idle unless gas pedal was tapped. 3rd test: more slack. Engine returned to idle after using hand throttle. 11: Road test! Works quite nicely. It's positioned low enough to be out of the way for shifting, but is right at hand. http://ecomodder.com/forum/member-hu...d-throttle.jpg The picture makes it look as if the switch sticks out far, but it also in a very comfortable location. Now all it needs is to be wired up! (probably not till after the trip though) 12: Issues: Both the hand throttle (in off position) and the switch touch the cupholder (extends out just below the large opening) when the shifter is in 1st, 3rd, and 5th gears. I haven't tried driving with the cupholder open yet. shifting in the driveway with it open seems to be ok. The range of motion of the throttle lever is quite large (150deg?), but the usable area is quite small. The engine dosn't come off idle until the 3rd click, and highway cruising at 70mph was about 7 clicks (abt 1/3rd of total motion). The previously mentioned clicks are a bit loud. I had a vague idea of how it could "cancel" when the brake or clutch was pressed, but decided for simplicity sake to just get it working first. I'd like to eventually go back and make that happen, as well as change the ratio to allow finer adjustments for the same motion. But that's all for another day. Even if it can be improved, it works as it stands, and will be light years better than nothing for my trip.:thumbup: |
Interesting mod. You'll have to let us know how it works out on your long trip. :)
Neat! Pictures of all the gorey details... and no apparent blood! :D Two points for surgical efficiency... extra parts for the next job!!! :p
I'll have to check that out when you are at the Missouri point of your trip. Wiring in a kill switch is something I need to investigate for future less-idiot-proof mods myself! :turtle: |
As long as you can get the speed dialed in correct on the highway, this should be better than cruise control for FE, since it is a fixed throttle position, it is DWL for you.
I'll definitely have a followup once I'm back home. So far I'm liking it!
------------ Nope, no blood sacrifices to the car gods; I'll have to try harder next time! :D I'm ready to have a kill switch too; I've been wanting to do it for awhile, when I was mounting the hand throttle that seemed to be the perfect place for the switch. Now I've gotta follow through and figure out how and where to wire it in, and probably will have to get (read "buy") a relay. (the switch I bought 10 yrs ago for a project, and had sitting around, the rest was free) I've got a repair book with wiring diagrams, just gotta find the right place in the diagram (easy) and find that place on the car (maybe not so easy). The start switch should be no problem; even though I'll have to tear the inside apart, the 2nd time will be faster since it's familiar ground. The plan right now has me headed to KC for the meet on the 27th, so you'll get to see it 1st hand.:thumbup: ------------- I've never really liked the way cruise control worked, especially in vehicles with auto trans. When I'm driving a vehicle with cruise once I start getting into hills most of the time I'll turn the cruise off anyway to keep it from upshifting and/or going full throttle. |
Relays!!!
Hey, I have a dozen or so relays sitting around somewhere! (I NEVER throw anything away... :D)
...must make note to self to dig out a couple of relays... I'm with you on the cruise control kicking down the tranny a couple of gears and going full-throttle. Had mine do that as I passed by a Highway Patrolman once... :eek: ...must make note to self to dig out a couple of relays... :o |
Hey, don't forget to make a note to yourself to dig out a couple of relays :D I don't throw anything away either (as evidenced by the 10 yr old switch) and find it hard to resist rescuing something that someone else is throwing away. Kind of funny, at work I've been helping replace the HVAC controllers in one of the buildings and running new wire between them. The only reason I haven't brought that old wire home with me is because I still have the large majority of the wire I took home from the LAST time I helped rewire that same building's HVAC controllers! :eek: |
The last time I did something like this, it was a hand controlled throttle built from a bike's brake handle. (I drive with one hand on the shifter most times, except if I'm racing.)
Obviously, it required a slightly heavier spring on the throttle, but I set it up with a cable clamp that just made it pull on the accelerator pedal's cable, instead of changing the throttle cam on the throttle body. I got so good at driving with it, I could drive with no feet after starting from a stop, by using the hand throttle and speed matching my upshifts and downshifts. |
Hugh Jim: DPDT relay, complete with schematic impressed into the case, IN HAND!!! I have no idea where it came from... it's been a lot longer than 10 years, since it was in '99 I got hurt. I think it is a headlamp relay. I hope the silly thing works... *worried face* |
Schematic on the case?!? What are you trying to do, spoil me?!? :D Anything I can bring you in exchange? Quote:
That was one of the two things I missed when I upgraded from that car: the other was it was a hatchback (masquerading as a sedan). Looked just like a sedan, but the trunk lid and back glass were connected and hinged at the top of the glass. So easy to load my bike. :thumbup: Oh, to return to the topic of the thread, the hand throttle has been working good. No problems shifting with the cup holder out. However, when I have some time I definitely want to work out a clutch/brake cancel, and "gear it down" for more sensitivity. As it is, I've taken to keeping a hand on it when I'm using it to make sure I don't forget to shut it off when I need to slow down. It's also a bit hard to pick and set a speed (though a lot of that is due to the highway being very inconsistent in slope). |
