Old 12-15-2011, 12:58 PM   #1 (permalink)
Buggie - '01 Vw Beetle TDI Gls
Air dam or lift kit
I understand the purpose of the airdam, but why not lift a vehicle with a suspension modification to increase ground clearance? With a belly pan it might be easier to slide through the air than to move all the air over the top of a vehicle. Given enough room under a vehicle it would slide through the air more like a v shaped plow than pushing all the air over. With the increased ground clearance and the higher pressure under the vehicle the downforce would also be negated, putting less load on the tires. Granted more of the tire would show but that could be negligible if the bottom of the car could be cleaned up enough to allow smooth airflow.
Old 12-15-2011, 02:25 PM   #2 (permalink)
Wildfire - '96 Ford Bronco XL
90 day: 14.88 mpg (US)
Blackford - '96 Ford Bronco XLT
90 day: 20.26 mpg (US)
Y2k - '00 Honda Insight
Gen-1 Insights
90 day: 73.98 mpg (US)
Redford V10 - '01 Ford F250 Lariat
90 day: 15.64 mpg (US)
FireFly - '00 Honda Insight DX
90 day: 69.43 mpg (US)
LittleRed - '00 Honda Insight
You wouldn't have smooth airflow coming out the back, which would help kill FE. If you could find a way to smooth the airflow coming AND going - then you'd essentially be an airplane on 4 poles (tires).
Old 12-15-2011, 02:42 PM   #3 (permalink)
You should calculate an estimation of how much more frontal area there'd be with that much tire exposed, then figure how much the Cd would have to improve simply to match what it was pre-lifted, let alone improve on it. IIRC belly pans have been generally credited with 10% aero improvement. Plus you'd want to fair the tires in some way so they don't muck up the flow around themselves and around that nice new pan.
