Old 01-29-2015, 02:14 AM   #1 (permalink)
Eddie25's Avatar
Fiesta - '06 Ford Fiesta 1.4 Ambiante
90 day: 45.9 mpg (US)
Dakar - '03 BMW f650 GS Dakar (retired)
Tucson - '07 Hyundai Tucson 2.0 GLS
90 day: 32.67 mpg (US)
Air dam shapes vs air dam delete
seeing more and more cars with air dams positioned well behind the front of the bumper almost in line with the front wheels. is there any research about different designs? u can see in pic belowClick image for larger version
below is my car with current air dam
[ATTACH]Click image for larger version
option 1Click image for larger version
option 2Click image for larger version
option 3Click image for larger version
I like option 1 and option 3
however with hatch backs space in the car needs to be utilised so more often than not you and up with a very flat bottom with no real air pockets or gaps. im considering deleting the air dam entirely and just improve the airflow under the car. I have seen posts where air dams were removed in favour of flat under trays but no results of that change?
Old 01-29-2015, 10:21 AM   #2 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Cant hurt to test the difference between a belly pan and air dam. When you go belly pan, you will still want to use tire spats to block the air hitting the tires. Harder core still would be tire boat tails front and rear (look up Arcosine's Saturn project for what I'm poorly describing).
I think OEM is using recessed air dams for multiple reasons. It's more hidden so it doesn't affect the looks of the car as much. Closer to the tires means you can go lower without scraping and it is less likely to get stuck on parking blocks. Also, some cars are set up as "bottom breathers" where the dam is actually integral to the cooling systems (C5 Corvette) and needs to be placed directly under the radiator.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
The Following 2 Users Say Thank You to spacemanspif For This Useful Post:
Eddie25 (01-30-2015), OG VX (01-29-2015)
Old 01-29-2015, 11:19 AM   #3 (permalink)
Experienced UAW Mechanic
Airdams need to be as far forward as possible. Sometimes removing them can reduce drag, but if the front goes light at 80 MPH, then you're endangering the people in the other cars around yours.
The Following User Says Thank You to cosmick For This Useful Post:
Old 01-29-2015, 11:42 AM   #4 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
I think an air dam of a given height works better at the front edge, than set back, because they have a stronger affect on the stagnation point, keeping more air out from under the car. I think the air dams set back more (but not bottom breathers) are like that because manufacturers are tring to protect them. My front overhang is longer than most newer cars, but the 2" air dam I added out at the front edge would be long gone by now if it wasn't made out of paver edging, which is stronger than the bumper material, and held on by about 15 1/4" bolts.
The Following User Says Thank You to 2000mc For This Useful Post:
