Old 05-25-2020, 05:56 PM   #21 (permalink)
Gotta stop using those fat ugly gottengen style windmill blade profiles and at least use something like a Selig 737 tailfeather airfoil which are less sensitive to angle of attack and have a lower cd.
I'd be happy to experiment with different aerofoil profiles if you can find another so cheap and easy to use (eg another extruded aluminum one). The other extrusions I can fine are just generic ie no aero data.
Old 05-29-2020, 09:27 PM   #22 (permalink)
I suspect that the leading and trailing edges are significant, but thickness mid-chord isn't.
I agree, but it must also be symmetrical, and chord length at some point becomes a factor in whatever the mid chord thickness is chosen.
All meaning to me, the thinnest possible at the requisite strength is the goal.
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 05:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 02:49 AM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 08:38 AM
Grill block affected milleage mar5ka Aerodynamics 24 08-31-2008 11:17 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 04:24 PM
