Old 04-22-2011, 12:52 AM   #11 (permalink)
mcmancuso's Avatar
Green Metro - '99 Chevrolet Metro LSi Sedan
90 day: 32.78 mpg (US)
Metro Vert - '91 Geo Metro LSi Convertible
90 day: 50.52 mpg (US)
Consumer reports did some testing on air filters a couple years ago, here's an excerpt:
"Change your air filter
The test team at Consumer Reports was sure that a car would get better mileage with a clean rather than a dirty air filter.
"It stands to reason that if the air is allowed to flow freely, it would result in better fuel economy," spokesman Douglas Love said.
To do the test, the team used duct tape to partially cover the air intake, simulating a dirty filter. And the result?
"We were surprised to find out it didn't much matter," Love said. "The mileage was about the same."
So, testers added a bit more tape and then some more. Short of blocking off all the air, they got the same results.
"We found that the onboard computers that adjust the fuel mixtures on recent cars did a surprisingly effective job," he said.
The auto club ran a test with clean and dirty fuel filters on several different cars. Results were similar.
"There was even one test where the mileage got a little bit better -- maybe 1% or 2% -- with the dirty filter," Mazor said.
But before you count the money you can save in air filters, there is a price to pay.
"The trade-off was that carbon monoxide emissions went up," he said."
TLDR: on fuel injected computer controlled cars, you're not going to see a FE difference in any filter, go for the best filtering capability to keep crap out of your engine.
Old 04-22-2011, 07:36 AM   #12 (permalink)
ZX - '97 Citroen ZX Monaco
OldContinents
90 day: 61.05 mpg (US)
Modern cars are indeed very nice with their computer controlled systems, but if car has a carb, dirty filter or partly blocked intake will cause fuel economy to collapse.
Reason is simple, carburettor is precision scale, it weights air and fuel and mixes them, that is why some carbs have altitude adjusting part, that changes mixture setting based on air pressure.
Also when there is more restriction to airflow than there was when carb was adjusted, then mixture will richen as more fuel is drawn.
It is very sensitive device that requires everything to be in "balance", but it is very accurate and can be tuned to use very little amount of fuel if conditions are constant.
Older mechanical fuel injection systems and some electronic ones are too getting some penalty from blocked air filter, they can't adjust as much and well as modern computer controlled system with O2 sensors, resulting rich burning.
So it is good to know what kind of system there is in a car and what changes are causing which effects, but best is to renew air filters enough often and at least oem filter does work in balance with rest of system.
