Old 10-08-2011, 02:26 AM   #21 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
You're adding a very inefficient air restriction in front of another very inefficient (variable) air restriction.
Ideally, you'd want to have a variable venturi to meter airflow, but such things tend to be very expensive to create. There'd still be the issue of pumping losses due to intake vacuum formation, but the variable venturi would pretty much remove losses due to throttling.
Nice try, though.
Old 10-08-2011, 04:41 AM   #22 (permalink)
The PRC.
Originally Posted by suspectnumber961 View Post
Someone has claimed that with a Ford Focus...removing the tube going to the front of the hood (fresh air) and allowing air to directly go into the bottom of the filter box resulted in increased mpg. Less restriction and warmer air.
I'll eventually try this...but won't like the noise when it's punched....the throttle that is.
I'm trying this with my Aygo at the moment by blocking the front nostrils which (theory tells me) feeds cold air to the intake. The intake is on the left of the box on top of the engine :
EDIT - Apologies is some people got an email of nonsense, I got the image link wrong.
This has made no difference to the intake temps so far though because this is heated anyway by the fact it sits on top of the warm engine. A guy I link to in my thread measured temps with a CAI and found that made no difference either because of the heated manifold effect.
So I have a warm intake anyway
On some of my older cars they had a water heated inlet manifold too.
Old 10-12-2011, 11:48 AM   #23 (permalink)
Transient
Commuter Plus - '98 Saturn SW2
Last 3: 37.12 mpg (US)
Rover - '07 Land Rover LR3 HSE
Last 3: 17.6 mpg (US)
Blackie - '16 Ford Focus Titanium Hatchback
90 day: 33.25 mpg (US)
Bertha - '11 Four Winds Chateau 31a
90 day: 7.79 mpg (US)
Van - '15 Honda Odyssey EX
Originally Posted by mwebb View Post
consider a carburated system from the 70s and a 2012 any car from now ....
same mass ,
FE is better by a huge percentage and emissions are greatly reduced on the
current systems compared to the 70s cars
While I agree this is true for american made cars there are exceptions and the 70s is a bad time frame to pick because of the gas crisis there were a LOT of very FE cars in the 70s. Additionally carbs and TBI were not that different FE wise in the 80s, we really only saw improvements with injectors and tuning improvements heading in to the 90s. Carbs actually vaporize fuel and I believe overall required less maintenance, injectors are just cheaper and easier to tune now.
I know this is the 80s, but I think it's worth noting this is 52MPG from a carb while GM was busy throwing a TBI on everything and still getting worse FE.
Anyway I agree with you overall, just wanted to point out that carbs could be quite amazing and while cars produce less pollution per unit of exhaust volume, I do not believe overall we're getting that much less pollution per mile.
Actually if you want to really go back you should look at when they first removed lead from fuel, only in the past 15-20 years have we really reclaimed that lost HP and FE from having to severally lower our compression ratios and tune for a cat that wouldn't really be necessary with the correctly build engine or tune.
Old 10-12-2011, 12:23 PM   #24 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Yes, but those are the old-old unadjusted epa ratings. Knock 25% off that to compare with today's cars. Old 50 = (about) 38 new. We have a whole crop of new econocars that beat that with a 40 mpg rating.
Old 10-12-2011, 01:41 PM   #25 (permalink)
I was just reading somewhere about the old EPA ratings... you can basically ignore the "highway" number and go by the other one.
Old 10-13-2011, 01:03 AM   #26 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
carbs are not quite amazing at all
i suggested that cars of equal mass were to be compared
a 1600 lb crx with a carb does not compare to a 2500 lb citation or k car with TBi -
when comparing cars of equal mass the system with fuel injection AND engine management wins a contest of fuel economy -
early CIS systems without engine management were only marginally better than carbs , but still , they were measurably better .
carbs are poor 2nd place even with engine management ... such as it was .
Old 10-14-2011, 04:16 PM   #27 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Give me ceramic engine block and heads and no restriction on Nox emissions and I'll give you an engine that will spank the rest in FE with a carb.
Note Ceramic engine blocks won't need a cooling system.
Old 10-14-2011, 10:40 PM   #28 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
Most people can. I've never gotten the "old" EPA city rating (19 MPG) with my Mustang. And since I found ecomodder.com, I only (occasionally) get less than the old "highway" rating on road trips. I must be doing something wrong.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
Old 10-14-2011, 11:37 PM   #29 (permalink)
mwebb's Avatar
EPA #s from the 70s and early 80s
i think FL was referring to the EPA claims from the 70s and early 80s - your car is a 2007 and it is not equipped with a carb
The Following User Says Thank You to mwebb For This Useful Post:
Frank Lee (10-15-2011)
Old 10-14-2011, 11:43 PM   #30 (permalink)
mwebb's Avatar
we must deal with what exists in the real world
i do not suppose such an engine actually exists nor will it ever find it's way to production because of durability issues -
and
in the real world , we do not want to use an engine that has no restriction on NOX production as NOX is very bad for humans , none the less , EGR can be used to limit NOX formation
on
any
engine
real , or imagined
