Old 06-08-2010, 10:31 AM   #1 (permalink)
Aspiring EcoModder
Eggy - '99 Saturn SL2
90 day: 43.7 mpg (US)
Alternator disable switch -- how much MPG improvement?
I know a few of you guys have installed a alternator disable switch. Just trying to get an idea of how much that will improve MPG (actual number or %). A "guesstimate" is fine since I'm still months away from completing all my mods.
My daily round trip commute with my 99 Saturn SL2 automatic is 64 miles (56 highway, 8 city) with some construction and traffic.
Old 06-08-2010, 10:32 AM   #2 (permalink)
Aspiring EcoModder
Forgot to mention that I did read the second half of DOAX's Paseo thread which includes the alternator switch.
Old 06-08-2010, 10:49 AM   #3 (permalink)
Darin (metrompg) tested this a while back. He saw a 10% improvement at steady state cruising.
http://ecomodder.com/forum/showthrea...n-70-a-98.html
Old 06-08-2010, 10:58 AM   #4 (permalink)
Aspiring EcoModder
Thanks Daox
Old 06-08-2010, 10:59 AM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
technically, Darin had removed the belt from the alternator so that it wasn't even turning. There would be less gains from just turning off the field. And it was a metro.
Old 06-08-2010, 12:02 PM   #6 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Mazda Protege DX
90 day: 46.42 mpg (US)
I did it on my 94 Toyota PickUp. I was not able to measure any change, I don't have a computer and tank to tank fillups with variations in temp/load didn't see any changes.
I do know I can feel a change in acceleration up a hill or a quick left turn in traffic with it off. Maybe I'm just using the switch in improve performance not improving gas mileage.
Don't get discouraged. I think if I had a scanguage or similiar and did A-B-A testing I would see a difference. Removing belt gets 10% so I would expect field switch at 5% or so.
Old 06-08-2010, 05:12 PM   #7 (permalink)
I have to start over?
Big inefficient truck - '94 Dodge Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Honda Civic DX Hatchback
I have a field switch, so when I get my MPGuino, I will be able to tell you a % gain. I won't be able to say MPG improvement, because I won't have it calibrated by then.
Sometimes, however, when I have the alternator off, the engine feels funny. Like the throttle is closing partway. It goes away when I turn the alternator back on. I suspect that it is the ignition getting less powerful with the low battery volts.
Old 06-08-2010, 09:04 PM   #8 (permalink)
Aspiring EcoModder
This alternator disable switch is one of the more extreme mods/tactics that I may end up not doing ... in the same boat as power steering pump delete and turning off the engine (during P&G). Maybe after exhausting the aero mods, I might reconsider.
Thanks for the input, though.
Old 06-09-2010, 09:04 AM   #9 (permalink)
90 day: 51.82 mpg (US)
Were you also recharging the battery from an external power source?
Old 06-10-2010, 09:44 AM   #10 (permalink)
busypaws: saw you answered my question in another thread:
I get about 20-30 miles before the radio starts lossing power then I know to turn alternator back on.
If you're not using an external power source to re-charge the battery, that explains why you're not seeing any fuel economy benefit.
Some vehicles use smart alternator control to eke out a few percent savings, but mostly by maintaining a minimum voltage under accel/cruise, and boosting alternator output under engine over-run and braking conditions.
Frank Lee (06-10-2010)
free OBD2 software with MPG calc whitewiz Instrumentation 11 12-10-2014 10:53 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 40 06-18-2012 03:13 AM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph MetroMPG Aerodynamics 500 05-10-2012 10:30 PM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
