Old 05-05-2020, 10:33 AM   #11 (permalink)
I dunno, seal it up pretty good, and use a submarine system to remove C02 and you could get away with a fairly small tank of O2. The tanks on the space station aren't that big. The pilots have to breathe their own separate air anyways, by law
Old 05-06-2020, 11:12 AM   #12 (permalink)
Originally Posted by Tahoe_Hybrid View Post
Air can be stored quite effectively in bottles when the ICE is running
Sure, but it also adds some weight and complexity. Holding compressed air for the engine starters is a whole different matter than having to store enough air to keep an airliner pressurized while cruising only on the electric motors or gliding. Considering some earlier pressurized aircraft had engine-driven compressors instead of resorting to air bleeding from the engine's compressors, maybe an accessory compressor driven by an electric motor shouldn't be so out of question. But anyway, it wouldn't surprise me if an electric motor becomes a viable replacement for both the reduction gear (when applied) and the accessory gearbox of an airliner engine.
Old 05-06-2020, 04:22 PM   #13 (permalink)
90 day: 29.78 mpg (US)
I made housings for the shuttle high-pressure fuel turbopumps at my first job out of school. 71,140 hp shaft horsepower from a pump a little bigger than a Chevy big block.
That is crazy... a fuel pump that is 71,140 horsepower. It must be moving a swimming pool amount of fuel in a minute or something.
It would be pretty simple to have an inlet on a high pressure surface of the aircraft provide the higher pressure.
Old 05-06-2020, 06:17 PM   #14 (permalink)
A skyscraper full of fuel and oxidizer in 4 minutes. See https://youtu.be/LbH1ZDImaI8?t=22 for a diagram of the competing open cycle, closed cycle and full flow variants.
You can't be wise and in love at the same time. -- Bob Dylan
ldjessee00 (05-08-2020)
Old 05-06-2020, 06:56 PM   #15 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
The Shuttle burned 535,000 gallons of liquid fuel in a little less than 9 minutes.
According to NASA, each pump (there were 3) would drain a swimming pool in 28 seconds. https://www.nasa.gov/centers/marshal...r/ssme_11.html
The High Pressure Pump (HPLT) was fed by a Low Pressure Pump (LPLT) The LPLT pressurized the fuel to 275 psi and then HPLT increased that to 6515 psi.
Full story here: https://spaceflight.nasa.gov/shuttle...p/engines.html
The Following 2 Users Say Thank You to JSH For This Useful Post:
freebeard (05-06-2020), Piotrsko (05-07-2020)
Old 05-07-2020, 12:22 PM   #16 (permalink)
You mean some sort of ram-air? Doesn't seem so easy to increase air pressure to the same extent now applied to the combined HVAC and pressurizing system of modern airliners.
