Old 07-09-2021, 10:21 AM   #1 (permalink)
AirShaper
here's some limited data on CFD vs full-scale tunnel testing
https://airshaper.com/blog/tesla-mod...c-benchmarking
freebeard (07-09-2021)
Old 07-09-2021, 12:58 PM   #2 (permalink)
Thanks. I'm curious as to how they got the scan of the underside of the Model Y.
It's also interesting that the scan couldn't find the bottom of the door gaps. They had to manually create what's called a 'watertight manifold'.
Now for the ball scores: 4 to 3, 6 to 2 and 8 to 1 -- Firesign Theater
aerohead (07-09-2021)
Old 07-09-2021, 01:20 PM   #3 (permalink)
curious
Me too!
Could be that they actually did a 3D-laser scan of the actual car, as input for the CFD software.
A research university in China previously published a CFD analysis for the Tesla Model S, and I believe that they did scan an actual car to get the data cloud.
A college mate, with aeronautical engineering degree from NASA, worked at Southwest Research Institute in San Antonio, Texas. They had a physical, 3D scanning device Glynn used to scan an US NAVY F-4 Phantom jet, then used to operate a walnut shell blasting media paint removal device which 'knew' where the aircraft 'was', incorporating optical recognition software, to ascertain 'when' the paint was satisfactorily removed.
If a car was mounted on a rotisserie, giving the physical probe access the underbody, it wouldn't be a problem to 'learn' the whole car.
It would take a long time though.
Old 07-09-2021, 04:11 PM   #4 (permalink)
A rotisserie is an uncommon item but they exist in body shops.
My thought was throw some straps through the window openings and lift it with a crane. But smart phone photogrammetry stitches together multiple pictures so it might have been done on a lift.
Old 07-10-2021, 10:05 AM   #5 (permalink)
Wouldn't you only need to have the scanner head be under the vehicle? Couple of cinderblocks under the tires should suffice or use mirrors to reflect the laser. Afaik, it is the RELATIVE distances that generate the dimensions, not the total distance.
Old 07-11-2021, 02:56 PM   #6 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
They have cooperation with a2mac1 who scan the vehicles and do full teardown for all cars. You can buy the scan file, reports conserning performance, manufacturing etc and comparisons to other vehicles etc. Airshaper then does simulations to that scan cloud. models are simplified to certain level depending what you want to study.
https://www.linkedin.com/in/vesatiainen/
Developing next gen wheels and tires which will give 20% more range in Tesla Model Y.
The Following 3 Users Say Thank You to Vekke For This Useful Post:
aerohead (07-14-2021), freebeard (07-11-2021), wouterremmerie (01-31-2023)
Old 07-11-2021, 04:39 PM   #7 (permalink)
For the lurkers: duckduckgo.com/?q=a2mac1
