Old 08-31-2009, 02:20 PM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
easy ev welder
Thought the EV crowd might appreciate this. Get the batteries and charger sorted out for your project, then use them for your welding tasks (with a pair of jumper cables)
from
DIY HACK – How to Make a DC Welder with a Golf Cart! | zedomax.com - The DIY, HOW TO, Hacks, Gadgets, and Tech Blog/Search Engine!
Old 08-31-2009, 05:33 PM   #2 (permalink)
bjn
I think a battery can't be a good MMA welding source since the current isn't limited. I've read MMA welders need constant current while MIG/MAG welders need constant voltage. So, a battery may be a good MIG welding supply.
Old 08-31-2009, 06:03 PM   #3 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
mma = manual arc weld, it was invented in 1888 (according to a web source)
it is primitive enough to think of this means to get it done. I watched vid and noticed transformer is one speed, no variation.
If to cheap into welding chores, go for modern mig with ".25 inch capable" specs, and avoid big brand names (as vid shows, they are that simple TRULY). This idea is clever however. Also with mig, you get an 18 volt instead of 12, I do not trust the home made one shown for this reason.
Old 08-31-2009, 06:32 PM   #4 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I weld with a battery charger most times, but I don't weld much, as I'm not too good at it.
For structural welding, not a good idea, probably - but for basic stuff, where only a good penetration is necessary, or "get me home" welding, it's probably just fine.
Old 09-01-2009, 04:33 PM   #5 (permalink)
This is what I used for my coupler. Very good with thick metal... but dont do it with thin ones.
EV59rag
Parting out my EV.
ES-31C D&D Motor
Alltrax 7245 Controller
Paul & Sabrina's Controller (never used)
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
New open source EV website - could use your help revoltev Introductions 1 08-02-2009 10:35 PM
Anybody have an EV info I was looking at a 99 Ford ranger EV or s10 GM EV? 95CHERJUST EcoModding Central 2 06-26-2009 04:17 PM
Chrysler's New EV Unveiled On CNBC This Morning! rgathright Alternative Transportation 5 02-09-2009 06:54 PM
Apparent yearly EV meet @ DVC in Concord CA Red General Efficiency Discussion 1 04-28-2008 08:50 AM
