Old 07-28-2009, 12:11 AM   #1 (permalink)
diablo2 - '12 Kia Forte EX
90 day: 31.92 mpg (US)
Stock V.S Aftermarket exhaust?
I was wondering if the stock manifold would be better than an aftermarket header?
I am not sure that the cost would be worth it right now. Its easily over 110 degrees out daily, so the A/C is on all the time! Showing up to work drenched is not an option.
Any input is appreciated.
Old 07-28-2009, 12:23 AM   #2 (permalink)
Yaris - '07 Toyota Yaris Liftback
A more free flowing exhaust gives better power but less fuel effieicney, and vice versa. You could block up your exhaust lol.
Old 07-28-2009, 12:27 AM   #3 (permalink)
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
Heres a cheaper solution.
beaded cushions, wood beads, wooden beads cushion, cushion, cushions, Seat Cushions, Car Seat Cushion, Auto Seat Cushion, Seat Cover, Car Seat Cover, Free Sun Shade, long lasting beaded cushions, bamboo cushions
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
Old 07-28-2009, 12:47 AM   #4 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Is that necessarily true? What I have understood is a LARGER exhaust usually hurts FE, since a larger diameter actually slows down the velocity and stagnates the flow at low revs. But keeping the factory size with a more free flowing design (headers, mandrel bent pipe, etc), shouldn't that help FE if anything? Seems like it would be part of reducing pumping losses.
Of course, any gains would be small and not worth the price of buying new parts. But if you need new parts anyway, then maybe.
Winter daily driver, parked most days right now
Summer daily driver
Old 07-28-2009, 05:32 PM   #5 (permalink)
It depends on the rpm range you're trying to make best use of and how restrictive the stock exhaust is. Different diameters, lengths, changes in volume all affect exhaust pulse velocity and scavenging (narrow rpm range where exhaust pulses reflected back from volume changes in the pipes return at the right time to help pull the exhaust through an open valve).
Does Exhaust Noise Play a Role in Fuel Economy? Metallover EcoModding Central 16 07-12-2009 09:47 PM
Civic Vx engine question. stock exhaust manifold vs. stock exhaust manifold vtecn8ive DIY / How-to 3 07-12-2009 01:07 PM
pumping losses- exhaust valve lift maclu24es EcoModding Central 4 06-20-2009 09:15 PM
New rules encourage PEHV aftermarket in California Ptero DIY / How-to 2 05-15-2009 01:36 AM
MetroMPG.com mailbag: various questions (final drive, exhaust, underdrive pulleys...) MetroMPG EcoModding Central 0 02-23-2008 08:40 PM
