Old 01-06-2010, 04:17 PM   #1 (permalink)
In persuit of Efficiency
zman's Avatar
Bouble - '01 Toyota Echo 2 door
90 day: 41.62 mpg (US)
Catalytic Converter Bypass Valve
Has anyone out there thought about bypassing the catalytic converter after the car has warmed up. How much power and milage gain would potentially be gained from bypassing it.
I did a quick sketch of possible bypass system with a shutoff valve. It seems to me it would be fairly easy to implement. The operator will be responsible for turning the system ON and OFF
Old 01-06-2010, 04:25 PM   #2 (permalink)
You wouldn't gain anything. Modern cats really aren't restrictions.
Old 01-06-2010, 06:07 PM   #3 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
It also wouldn't be an "EcoMod"
Old 01-06-2010, 11:14 PM   #4 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
I'm with everyone on this, But I can tell you that I have been around a few Ferraris that did exactly what you are talking about.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
The Following User Says Thank You to dremd For This Useful Post:
dave77 (01-07-2010)
Old 01-06-2010, 11:39 PM   #5 (permalink)
Yep I have to agree about modern cats being efficient.
Bypassing them would result in virtually zero gain for either performance or fuel savings.
Just my 2c worth , Pete.
Old 01-07-2010, 01:19 AM   #6 (permalink)
Seems bass-ackwards on several levels.
For one, the cat doesn't work very well when it's cold. So you're going to run gases through it when it doesn't work, then when it's warm enough to work you bypass it??? I'd say with that logic just tear it out... but as noted, the cat isn't the biggest restriction and even if it was, tearing it out doesn't help fe.
dave77 (01-07-2010)
Old 01-07-2010, 02:17 AM   #7 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
if you take it out it will gain 5.3 HP on a dyno on a 1985 Ferrari 308 GTS quattrovalve Not that i would know
Just winds up giving you more throttle response but not very good eco wise
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 01-07-2010, 07:15 AM   #8 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
I can see how this could help at 7k rpm at WOT, but cruising along at 1700 rpm? Gains would be slim to none, and surely not noticeable. Plus it's totally illegal on roads.
www.HyperKilometreur.com - Quand chaque goutte compte...
The Following 2 Users Say Thank You to tasdrouille For This Useful Post:
Daox (01-07-2010), dave77 (01-07-2010)
Old 01-07-2010, 11:28 AM   #9 (permalink)
Well not places that don't have emissions laws
Tank:
Old 01-07-2010, 11:35 AM   #10 (permalink)
Hes in the US, you need a CAT to be legal.
The Following User Says Thank You to Daox For This Useful Post:
dave77 (01-07-2010)
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Intercooler bypass valve Piwoslaw EcoModding Central 17 10-20-2010 03:26 AM
Has anyone tried making/using a catalytic converter warmer? twolostminds EcoModding Central 79 01-09-2010 05:56 PM
