Old 03-29-2013, 11:43 AM   #1 (permalink)
Alternator with magnetic coupling?
Hello people
Why not a alternator with magnetic coupling (Clutch)?
When the battery ist full, the shut down the alternator?
5-7% better efficiency?
cu
PowerPiston
Sorry my english is not good. I come from Switzerland.
Old 03-29-2013, 11:54 AM   #2 (permalink)
Welcome to the site. Alternators do not put a constant load on the engine. If the battery voltage is low they put out a lot of current. If the battery voltage is high they don't put out a lot of current. There really isn't a reason to physically decouple the alternator from the engine. Even the guys who do 'alternator deletes' usually just install a switch to stop the alternator from generating any power versus physically changing things.
Old 03-29-2013, 11:55 AM   #3 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
There have been ideas before about putting an air conditioning compressor on the alternator. From what I have heard the size of the pulley may cause issue with charging the battery because it is too big.
Project Avalon: E bike build
Old 03-29-2013, 12:22 PM   #4 (permalink)
the friction of the alternators is not to be underestimated
Old 03-29-2013, 12:31 PM   #5 (permalink)
Have you spun an alternator by hand? Its quite easy to do. The friction is nothing compared to everything else going on in a car.
Old 03-29-2013, 12:37 PM   #6 (permalink)
The main energy loss would be in belt friction, so you would need to have the decoupling on the crankshaft pulley. The problem is that the same belt often drives fans, power steering pump, etc.
The Following User Says Thank You to jamesqf For This Useful Post:
Ryland (03-29-2013)
Old 03-29-2013, 12:39 PM   #7 (permalink)
No i haven't.
Old 03-29-2013, 01:02 PM   #8 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
You can spin an alternator with no load pretty easy. An alternator with load isn't so easy.
Old 03-29-2013, 01:24 PM   #9 (permalink)
...beats walking...
...simply attach an AIRCONDITIONING CLUTCH to the alternator, that way YOU can control it's mechanical coupling & engagement whenever you want...or, have it electronically controlled by something.
Old 03-29-2013, 02:45 PM   #10 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Belt friction isn't much either. Obviously more than no belt, but that's hard to do. The latest Toyota hybrids are completely beltless, so obviously there is some gain, but in the grand scheme of things? Like Daox said, it's not much.
The best would be like what Mazda is doing soon. The alternator charges when decelerating and turns off when accelerating, and charges a large capacitor to keep the charging system happy all the time. Maybe someone needs to invent a DIY version.
