Old 12-06-2009, 10:31 PM   #1 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Warm air intake on radiator?
Has anyone hooked the air intake to the backside of the radiator to pull nice warm air? Seems it would be pretty easy. Just wondering if anyone has done it and how they did it to keep things neat.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 12-06-2009, 10:40 PM   #2 (permalink)
Maroon Ballon - '98 Chrysler Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Geo Metro 5spd hatch, 3 cyl
Placing an intake in the vicinity of the exhaust manifold seems to be easier and more effective. Behind the radiator you have the fan, and in a lot of vehicles, there isn't much room to put much of anything there.
Old 12-06-2009, 10:43 PM   #3 (permalink)
Team Pontiac
good point...somehow i forgot that all cars are different. nt
1991 F-250:
Old 12-06-2009, 11:08 PM   #4 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
Yes
Yes, I'm doing it now. My exhaust is heat wraped so I don't get enough heat from it for the HAI. So I pull off the radiator. I run 40-50 degrees above ambient with it. I need more heat...but it was super easy to make. 3" dryer duct, duct taped to the air box and routed to radiator.
ID:	4963   Click image for larger version
Old 12-06-2009, 11:25 PM   #5 (permalink)
I think you will find this of interest. In reading many posts about cold vs. warm air intake, I looked at the intake on one of my cars, a 1989 Mitsubishi Galant. I was intrigued to find that it has a large, long sealed tube that leads from the radiator to the air filter can. The other tube, which is the actual intake, draws air from an enclosed box just behind the grille at the fender, away from the radiator. (See attachment of diagram of the entire system. It's #3, simply called "branch tube".) Apparently this setup is meant to blend cold and warm air, as needed. The sensor unit is very large and is mounted literally inside the air filter itself.
Since the car has always gotten (relatively) good mileage and has very good acceleration as well, I'm not about to start modifying it. I think the design of this system might provide clues as to what is most effective in the ongoing intake & air temp debate.
Old 12-07-2009, 12:48 AM   #6 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
HA! You're doing the WRAITh we discussed in the other thread!
(Warmed Ram Air Intake Thing)
EDIT: Are you?
Old 12-07-2009, 01:02 AM   #7 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
not a good idea.
I asked this about a carbed v8 that stayed cold (I wanted to make it warmer faster)
the reason by the ase mechanic:
the radiator rids of stuff through radiation, including some of the coils energy.
if its low volt, you make the engine a pig through ionization.
alot of engines have plastic over the top if one hasn't noticed, it helps the radiator stay away from intake.
alot of four cylinders, they are sensitive to this very physic. even my 23 year old has plastic all across the front of the engine, inline fours have the same. bigger engines pretend to own themself, its hilarious...(name a v8 gas with 200k on it)...
you can experiment, and dig out the sludge from the oil pan as a result, that is the friendliest outcome. I have gone as far as cold air intake for a carb, and suffer the long time waiting to warm up...just for the clean I know is happening. fire in fire out, fire once good and strong, no recycle. Even the alternator gets a flow, easy does it, blue sparks instead of yellow for the wires ...
Old 12-07-2009, 01:57 AM   #8 (permalink)
Does anyone else hear a buzzing noise?f
bgd - Are you suggesting that the radiator carries and expels excess electrical energy? That's funny... most of them are mounted on rubber isolators.
Old 12-07-2009, 02:01 AM   #9 (permalink)
ENGELHARD DEVELOPS NEW CATALYST SYSTEMS THAT ALLOW AUTOMOBILES TO DESTROY SMOG; The technology is a potential clean air breakthrough. - Free Online Library
Well they can be made to do strange things...
Old 12-07-2009, 02:04 AM   #10 (permalink)
Of course they can... you could do that same thing on any surface through which air travels, though. You don't see everyone coating their screen doors and windows with catalyst, do you?
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Warm air intake, how warm can you go? zman General Efficiency Discussion 8 04-28-2009 06:13 PM
My Warm Intake & Temp #'s (mileage results tonight) Drive Stick EcoModding Central 4 03-26-2009 10:25 PM
Grill block affected milleage mar5ka Aerodynamics 24 08-31-2008 10:17 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
