12-07-2009, 02:06 AM
#11 (permalink)
What are we waiting for?
Spray bombs with that coating?
12-07-2009, 02:13 AM
#12 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
I think we're just waiting for that coating itself... I haven't heard of any marketed version of it.
Isn't it kinda like those Ionic Breeze things?
12-07-2009, 10:43 AM
#13 (permalink)
Originally Posted by bgd73
not a good idea.
I asked this about a carbed v8 that stayed cold (I wanted to make it warmer faster)
the reason by the ase mechanic:
the radiator rids of stuff through radiation, including some of the coils energy.
if its low volt, you make the engine a pig through ionization.
alot of engines have plastic over the top if one hasn't noticed, it helps the radiator stay away from intake.
alot of four cylinders, they are sensitive to this very physic. even my 23 year old has plastic all across the front of the engine, inline fours have the same. bigger engines pretend to own themself, its hilarious...(name a v8 gas with 200k on it)...
you can experiment, and dig out the sludge from the oil pan as a result, that is the friendliest outcome. I have gone as far as cold air intake for a carb, and suffer the long time waiting to warm up...just for the clean I know is happening. fire in fire out, fire once good and strong, no recycle. Even the alternator gets a flow, easy does it, blue sparks instead of yellow for the wires ...
I've read this twice and still have no idea what you're trying to communicate???
I'm just hoping I'm very confused and don't have to worry about my car leaking radiation to the environment from my radiator?
Doug
12-07-2009, 10:44 AM
#14 (permalink)
Boy did this thread take a wander.
Back on topic though, i guess it would make a difference but it may vary between a gasser and a diesel. The heat output from a gasser is much higher than a diesel so you may get plenty of heat going to your intake, which would give good lean burn-ability. Warmup times may not be quicker due to the thermostat opening when the engine reaches operating temp.
In a diesel there may be scope for the intake being the sole means of airflow to the radiator. The reason i say that is that mine is currently completely blocked off. There is some air getting to the radiator due to leakage from under the bumper etc. but it's grille is completely blocked all the same.
But what is the optimum air temp for a diesel in terms of FE?
ollie
12-07-2009, 11:22 AM
#15 (permalink)
I only know the EGT for the diesel when it's running efficiently, which is ~600* at cruise (low load).
Even if your grille is completely blocked, if your intake piping is sealed (as much as it can be) against the radiator, it will still pull air through it. There is airspace under there, even if you've blocked the section that normally permits flow. The engine's vacuum will find an air source, with no problems.
12-07-2009, 11:42 AM
#16 (permalink)
I'm wondering if anyone else has a vehicle similar to my Galant that has that air warming tube along the radiator as the OEM setup?
12-07-2009, 11:44 AM
#17 (permalink)
4th gen Civics and 2nd gen CRX's have an intake "mixer" above the radiator that draws heat from the upper end tank.
12-07-2009, 12:18 PM
#18 (permalink)
Originally Posted by Christ
HA! You're doing the WRAITh we discussed in the other thread!
(Warmed Ram Air Intake Thing)
EDIT: Are you?
Yep  Gonna just duct tape a cheap heater core to my intake and see how it compares. What I have now is just not enough surface area and the pipe is very long, about three feet. Then I'll duct tape some pipe onto that for ram air and see what happens.... Kinda, A,B,C,D,C,B,A test
12-07-2009, 12:21 PM
#19 (permalink)
Just imagine what that table is going to look like...
Next vehicle is getting a heater core mod to the intake... using the variable flow valve that most vehicles have, you can control the IAT almost precisely, just like the heater in the car can be controlled, by a cable connection and a lever.
If you're really clever, you can control that valve with an Arduino and a stepper motor, with a temperature sensing circuit that will adjust according to a pre-set temperature specification.
