Go Back   EcoModder Forum > AltModding > Saving@Home
Old 04-26-2012, 10:15 PM   #71 (permalink)
sid
grayranger - '10 Ford Ranger XL 2 door supercab
90 day: 31.53 mpg (US)
I've been using a radiant barrier for over 25 years with the only degradation caused by people crawling through the attic. Those damaged areas were either taped with aluminum foil tape or stapled back in place. There appears to be no degradation of the material itself so far.
2010 Ford Ranger, extra cab, 2.3 liter
http://www.stonemarmot.com
Band's latest song/music video "Black Hole Jezebel"
Old 04-30-2012, 02:08 PM   #72 (permalink)
Great to know the material holds up so well. After seeing a sample of it and seeing how strong it was I suspected it would last for many years. Mine is stapled to the sheeting directly under the metal roof so it's worst abuse probably comes from the heat. The metal is warrantied for either 30 or 40 years and if it lasts 40 years someone else will likely be putting the next roof on since I'd be 91 years old and likely be dead. Do you have any idea what the percentage savings it made in your energy costs were? We've already had days in the mid 90's this year, but the house stayed comfortable until late in the afternoon even without using the a/c.
Roof rack test: quantifying the aero penalty MetroMPG Aerodynamics 30 02-10-2023 08:18 PM
Commercially produced aerodynamic pickup bed cap MetroMPG Aerodynamics 636 01-09-2022 06:21 PM
How to reduce drag of surfboard roof racks? Palionu Aerodynamics 11 04-28-2012 02:15 PM
removing roof rack cross bars= better gas milage? mntbiker2008 Aerodynamics 9 03-25-2008 08:54 PM
Strange OEM Aerodynamic Shape (longitudinal roof indents) LostCause Aerodynamics 17 03-19-2008 11:26 PM
