Old 09-10-2009, 10:34 AM   #1 (permalink)
Using E85 in TDi VW
Does anyone know if you can pump E85 Ethanol fuel into a diesel motor, specifically a VW Golf 1.9 TDi? I live in Orlando and would love to pump B20 or B100 into it regularly, but stations are limited. I do however have access to E85 easier and would love to use it if it is safe.
Thoughts, suggestions?
Thanks.
Old 09-10-2009, 11:35 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
dunno, here is a diesel that runs ethanol,
Scania’s Ethanol Diesel-Engine, Runs On Biodiesel Too : Gas 2.0
it has more compression and bigger injectors and probably numerous other tweaks.
Old 09-10-2009, 12:38 PM   #3 (permalink)
vdub - '86 VW Jetta GL
90 day: 47.64 mpg (US)
Nononononono please don't do that! You'll trash your engine. Some people with old Mercedes diesels have used 85% veggie oil and 15% gasoline premixed, but this is not recommended. The TDI injection pump and seals are already sensitive to excess methanol and water from homemade biodiesel. Ethanol is a big no no.
'scort no longer- '86 VW Jetta diesel - biodiesel
Old 09-10-2009, 04:23 PM   #4 (permalink)
What about MPG's?
Will your vehicle obtain better MPG's by using Biodiesel or even straight vegetable oil, rather than running on regular diesel??
Old 09-10-2009, 04:34 PM   #5 (permalink)
Most people agree that there's not too much difference in MPG for biodiesel or petrol diesel. Biodiesel has slightly less BTUs, but has higher cetane, and additionally is a better lubricant so your engine will run quieter and smoother. Petroleum based diesel has more BTUs but lower cetane and crappy lubricity (unless you use additives, or blend biodiesel).
HTH!
E85 - Anyone else getting great results? Rower4VT EcoModding Central 38 05-18-2011 01:10 PM
VW TDI advice jwxr7 The Lounge 15 12-03-2009 05:24 PM
VW TDI vs. Gas comparison guudasitgets General Efficiency Discussion 99 11-27-2009 08:12 PM
jetta flexfuel convertion to E85 jetta2.5L Fossil Fuel Free 2 05-20-2009 04:27 AM
FS: 1996 VW Passat TDI G60ING For Sale 0 02-26-2009 07:12 PM
