Old 10-28-2009, 07:10 AM   #1 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Fuel consumption data from a scan tool?
I have a Tech 1A scan tool that works in my 1994 Metro. Can I rely on this to give me instantaneous fuel economy feedback by watching the injector pulsewidth at a given speed? I know it won't give me MPG, but I'll be happy as long as I can see if what I'm doing is helping or hurting.
Old 10-28-2009, 09:44 AM   #2 (permalink)
...beats walking...
...theoretically, yes.
...practically, no.
...remember, cylinders do NOT all combust exactly the same, so the computer has to continually play a "tweeking" game between cylinders to maintain an AVERAGE optimization, rather than an individual optimization of any specific cylinder. This is because the "feedback" mechanism are the common 02-sensors, ahead of and behind, the catalytic converter...which means averaged feedback about the aggregate exhaust, not specific feedback for any one cylinder.
...nevertheless, you probably CAN gain some knowledge about what's going in the ONE cylinder you're monitoring...plus a lot of mental "integrating" of what you're seeing.
Old 10-28-2009, 10:50 AM   #3 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
This is a TBI car, so there's only one injector.
Old 10-28-2009, 10:57 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
the injector duty cycle can be a relative indication of gallons per hour. You can use it for relative mpg by doing the math in your head (mph/duty cycle) and try to get the lowest duty cycle for any given speed.
Old 11-30-2009, 10:08 PM   #5 (permalink)
hi...
Anyone know how to make it work on the SR20 ecu? could be very helpful.
Thanks in advance..
Old 12-02-2009, 01:43 AM   #6 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Originally Posted by johnvarenda View Post
hi...
Thanks in advance..
It should work on any vehicle if you can get the correct cartridges and cables for it. I only have the Suzuki stuff.
Old 12-04-2009, 01:34 AM   #7 (permalink)
HI,
PC based OBD-II Diagnostic Scanner can retrieve and describe both generic and manufacturer specific Diagnostic Trouble Codes (DTC's) giving you valuable information about why your check engine light (MIL) is illuminated.
Once a trouble code has been retrieved, you can use the scan tool to check for the cause by looking at live sensor data, emission related test results and sensor data from when the trouble code was set.
Once the problem is identified and repaired, the scan tool can reset the check engine light and clear the trouble code....
Thank you...
Old 12-28-2009, 11:04 PM   #8 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
if you have a
LOAD
or
Calculated Load
PID parameter ID
monitor that , NOT IPW
lower is better for FE
but
i do not know if OBD1 will have it
Hydrogen Generator Experiment willy57 DIY / How-to 601 08-23-2016 05:53 AM
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
Aerodynamic Heavy-Duty Truck Trailer Cuts Fuel Consumption and Emissions By Up to 15% SVOboy Aerodynamics 11 12-27-2011 07:18 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
Emissions Standards - "Good For Fuel Efficiency," Consumption Data Says trebuchet03 General Efficiency Discussion 11 04-18-2008 01:15 AM
