Old 12-03-2012, 08:10 AM   #1 (permalink)
Workstar - '01 Ford Windstar SEL
90 day: 20.12 mpg (US)
2003 Expedition - '03 Ford Expedition
90 day: 14.96 mpg (US)
Successfully unsuccessful Neon gear swap
Greetings. I recently picked up a 96 Neon SOHC auto trans to use for running my 100 mile/day courier route and for me or my wife to drive when we are going somewhere solo. I had heard that there were some different transfer gears available for the 3 spd auto and did some research. I found that the Neon came with a 1.04:1 ratio and that a lot of late 80's Chrysler's had a .91:1 gear set. I was able to find an 87 Plymouth Horizon in the junkyard with that gear set and only paid $10 for the gears so at least my investment wasn't much. Prior to the gear swap I was getting 31-34 mpg. I did the swap and dropped my 70 mph rpm from 2900 to 2400 so I was expecting a good increase. I have filled up twice and got 31.9 and 32.9 so I didn't exactly gain anything. At the very least the engine isn't as noisy and screaming at highway speeds and the acceleration didn't seem to drop much. I predict that on a long highway run the increase would be much better.
Old 12-03-2012, 10:41 AM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
lowering rpms is always a good thing.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 12-03-2012, 11:03 AM   #3 (permalink)
I don't see a gas log, and it is winter. Two trips is not enough to pass judgement on the efficacy of this.
Old 12-03-2012, 11:03 AM   #4 (permalink)
The temperature is fluxuating so much at this time of year to get any good numbers.
Old 12-03-2012, 11:24 AM   #5 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Does the speedometer read correctly or is it under reporting miles?
Old 12-03-2012, 04:27 PM   #6 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Dropping from 2900 to 2400 without the gear swap would of had more of a gain! Which way the wind is blowing makes a 5 mpg difference on my car.
- Tony
Old 12-03-2012, 04:38 PM   #7 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
I'm with ksa8907. I don't know how that car calculates mileage, so I don't know if it's reporting the right numbers. How regular is your route, grswat? Is there a part that you know what your car always reads a certain distance, and is that the same?
Transmission type Efficiency
Old 12-04-2012, 07:33 AM   #8 (permalink)
I agree that 2 fuelups are not a for sure thing but was hoping for significant immediate improvement.
Yes the speedo/odo read correctly the gears are before the speed sensor.
My route is the same everyday, probably about 85 miles of interstate and 10 in town with very little traffic (at 4 am) but a dozen lights or so. I'm just dividing miles by gallons at fuel up to calculate.
