Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 05-20-2014, 11:56 PM   #11 (permalink)
Oxygenated fuel is good- that's why having ethanol blended in is good.
Old 05-21-2014, 03:42 PM   #12 (permalink)
Depends on what you're blending with.
As far as pressurizing gas tanks: Wouldn't that alter fuel line pressure and if raised enough, cause the engine to run rich, then causing the ECU to re-trim leaner?
Old 05-21-2014, 03:57 PM   #13 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
yes.
enough pressure and you can double fuel flow per time unit, causing an indicated 100% gain in MPG on a trip computer.
reality, no change. well, actually, worse since the energy to pressurize the tank isn't free, but it will show nearly double.
Old 05-21-2014, 09:44 PM   #14 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Originally Posted by RobertISaar View Post
yes.
True, the trip computer is calibrated to the stock pressure (more pressure = more flow). Also trip computers only read fuel injected at the injector. Force fuel through the canister/evap system, and its like "free" gas that the trip never sees.
Shooting for 600 miles of range at 65-70 mph out of a vx.
Old 06-08-2014, 12:38 AM   #15 (permalink)
Fuel aeration, like what most carburetors have used for 40 years to help mix air and fuel?
Old 06-08-2014, 12:29 PM   #16 (permalink)
...beats walking...
...which was called "vapor lock" when air bubbles were entrained in gasoline (due to heat) in carburetors...but not a problem now with fuel-injection which uses high-pressure fuel.
Remember, there are TWO ways to make a liquid evaporate: (1) reduced pressure and/or (2) increased temperature (heat).
Old 06-08-2014, 02:02 PM   #17 (permalink)
I have had vapor lock on my camaro it sucks..
In a carb like a Carter, eldbrock there are air inlet ports and air mixer tubes that look like tiny machine gun heat shields down in side the carb housing that premix air and fuel between where the fuel is metered by the jet and introduced to the intake stream at the venturi.
If one of these air ports gets plugged up the engine will run crazy rich.
Old 06-08-2014, 02:49 PM   #18 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.65 mpg (US)
yes.
That much pressure will make the entire fuel tank go KABOOM, spraying atomized fuel in all directions, to be ignited by any spark. Result is a fuel air bomb. A big one.
Old 06-10-2014, 01:01 AM   #19 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
What a Lark , the fuel gets all the oxygen when being sprayed threw injectors (about 45psi) or Jets on Carburetors ( 4-15 psi est.)
I did not see how many psi he uses for his pressurizing ( fail ) experiment , regardless of what psi he apparently used it would do nothing other then feed the fuel faster for a quicker drain, if anything at all.
Drill into the fuel tank ? now that's good advice..
Save gas
Old 06-10-2014, 01:23 AM   #20 (permalink)
ecomodded's Avatar
JR I Believe the pressure could burst a seam / line with his rigged up tire pump as well let alone just pressurizing it , what hazard to put it mildly. Funny how he says he is cutting his fuel cost in half and thinking we are all stupid for not doing it.. He is a very Imaginative fellow.
Save gas
