Old 05-10-2009, 11:35 PM   #1 (permalink)
my first gmc's Avatar
Sierra - '96 GMC Sierra
90 day: 20.89 mpg (US)
White Lightning - '10 Mitsubishi Lancer GTS
90 day: 27.18 mpg (US)
led question
Ok, I'm wiring up some led tail lights. What kind of viewing angle should I get for the leds? Would a higher mcd led with small angle, or a lower mcd led with wider angle be better?
Thanks
Old 05-11-2009, 09:01 AM   #2 (permalink)
McTimson's Avatar
Maverick - '22 Ford Maverick XLT
90 day: 40.02 mpg (US)
For tail lights, you're not really trying to illuminate anything, you're just trying to make your presence known. So, you don't really need a huge viewing angle for them. I would go with the higher mcd rating, unless the angle is only like 5 degrees on them. I think most are around 15 degrees though, so a high mcd with that should be alright.
Make sure they're not too bright though, you don't want to blind people at night.
Old 05-11-2009, 11:00 AM   #3 (permalink)
Modding for Eris
Thalass's Avatar
SilverCivic - '08 Honda Civic
90 day: 28.69 mpg (US)
You could have several LEDs in the one lamp, at slightly different angles to spread the overall coverage. Quite a few cars nowdays have twenty or so LEDs instead of a single light.
Making do with a Honda Civic. Tesla Model 3 reserved. Still kinda want an SVX for fun, though.
Old 05-11-2009, 11:12 AM   #4 (permalink)
Impala - '04 Chevrolet Impala base
90 day: 32.84 mpg (US)
From the rear, a wider angle is better as long as the light output is good on all angles. A narrow angle can incrase the risk of being rear ended by an inattentive driver.
Old 05-11-2009, 02:43 PM   #5 (permalink)
Funny, I would think "not trying to illuminate anything" would mean you want a wider less-concentrated amout of light. It's always good if someone who isn't directly behind you can still see some red light that denotes where the back of your car is.
I'd go for as wide a viewing as I could reasonably get. Probably with multiple LEDs pointing in different directions, or possibly with a diffuser over them. The more people who can see where my car is, the better!!
-soD
Old 05-11-2009, 03:40 PM   #6 (permalink)
Misanthropologist
captainslug's Avatar
BORK! - '89 Volvo 240 DL Wagon
90 day: 21.27 mpg (US)
The LED brake light units on school buses, commuter buses, and semi-trucks use 12mm diameter LED in collimator arrays, or 5mm LEDs in diffusion lenses.
You don't really need a wide viewing angle for them to be effective.
Old 05-11-2009, 05:25 PM   #7 (permalink)
McTimson's Avatar
I was thinking that since you have to use several LED's anyway, the 'viewing angle' would pretty much be covered by the fact that you're using several in an array. Since you sacrifice brightness when you increase the viewing angle of an individual LED, you might as well get several bright ones in an array rather than several dimmer ones that would hardly increase the overall angle of the light.
Old 05-11-2009, 09:25 PM   #8 (permalink)
Ok cool, so i guess I'll order some 5mm 8000mcd with 30*. I'm going to have about 25 or 30 in each tail with what I think is a diffusing lens. These are the lenses I'm putting leds in:
Thanks guys.
My LED tail light conversion BrianAbington EcoModding Central 52 12-06-2011 06:42 PM
LED Headlight captainslug DIY / How-to 82 11-15-2011 01:32 AM
LED lighting goes mainstream! It's at Wal-Mart! bennelson Saving@Home 81 08-07-2010 11:18 AM
Video: LED battery pack monitor / bargraph MetroMPG Fossil Fuel Free 0 05-04-2009 09:59 AM
Article: Hella LED Headlamp Study TomO General Efficiency Discussion 14 10-21-2008 02:39 PM
