Old 04-17-2015, 03:04 AM   #1 (permalink)
Ford XLT Naked - '14 Ford F-150 XLT
90 day: 15.04 mpg (US)
Ford G-4 with Stinger - '14 Ford F-150 4X4 Super Crew XLT
90 day: 19.8 mpg (US)
Ford Stealth G-4 - '14 Ford F-150 4X4 Super Crew XLT
90 day: 16.79 mpg (US)
XLT Towing Keystone 5th wheel trailer - '14 Ford Keystone 5th Wheel XLT
90 day: 9.03 mpg (US)
Trip 2015 C Max Energi - '15 Ford C Max Energi SWP
90 day: 38.2 mpg (US)
Local 120 volt 2015 C-Max Energi - '15 Ford C-Max Energy SEL
90 day: 55.65 mpg (US)
Local 240 volt 2015 C-Max Energi - '15 Ford C Max Energi SLE
90 day: 57.63 mpg (US)
Energi Combined - '15 C Max Energi Leather
90 day: 51.2 mpg (US)
MoonDust for Travel - '19 Chevrolet Bolt LT
90 day: 123.11 mpg (US)
MoonDust 3 with 90% CE - '19 Chevy Bolt LT
90 day: 127.57 mpg (US)
Ecopia IV - '19 Chevy Bolt Lt
90 day: 126.39 mpg (US)
Ecopia IV Trip Log - '19 Chevy Bolt LT
90 day: 121.01 mpg (US)
Rate Rider Chevy Bolt - '19 Chevrolet Bolt LT-2
90 day: 123.16 mpg (US)
Teal Force One 70% - '24 Hyundai Ioniq 5 SEL
90 day: 98.52 mpg (US)
Teal Force Two 90% - '24 Hyundai Ioniq 5 SEL
90 day: 110.72 mpg (US)
Apex Trailer Towing with Ford F 150
I hooked up our 23 ft trailer today and towed it down to Griffin Propane to get a gas leak fixed. Turned out I needed a new two way valve as it was leaking. This is the first time I have towed our trailer with our new truck. I was curious how it would do compared to the 4 Runner and the truck did well. It appears to get pretty much the same mpg's (around 12 mpg's) but the truck definitely has more power. Same engine (3.5 L V-6) but the Ford has dual turbochargers. I had to go around a farm tractor and it just up and went around it with alacrity.
I am looking at rigging up some cross bracing and triangulated supports so I can tow with the Aerolid lift gate up. If I can do this it will kick the air up towards the trailer roof and that could be a good thing. We will see, if I can not support the lift gate securely I will not attempt it. Be nice if the open areas could be filled in. We are hoping to sell the the trailer so I don't want to get sidetracked on this projects.
The Following 2 Users Say Thank You to aerostealth For This Useful Post:
aerohead (04-17-2015), BamZipPow (05-02-2015)
Old 05-01-2015, 05:44 PM   #2 (permalink)
Towed this trailer today with the Ford with the Aerolid mounted and I was getting a honest 20 mpg return at 55 mph. The trailer weighs 1100 lbs and only had nine 16 ft composite boards in it for decking. I used to get between 17 mph and 18 mpg towing this trailer with my 4 Runner. More of the trailer seems to be in the the shadow of the truck as the truck is wider and the Aerolid seems to make a big difference.
aerohead (05-01-2015), BamZipPow (05-02-2015)
Old 05-02-2015, 12:56 AM   #3 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
My thread on my adventure with my aero cap and towing a trailer...
http://ecomodder.com/forum/showthrea...ler-25336.html
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (05-02-2015)
Old 05-02-2015, 02:33 AM   #4 (permalink)
I would say your problem with a higher trailer was a mpg killer. I am looking at a strut bracing system to hold the lift gate of the Aerolid up so air can land higher on the Apex trailer when I tow it. I will need a side curtain to stop air from bleeding around it.
aerohead (05-02-2015), BamZipPow (05-02-2015)
