Apexi V-AFC and auto-timer in VX
found this in my closet today. a 1rst gen APexi V-afc meter . Since this can adjust fuel +/- i think 5% i will use it with a BOOMSLANG plug n play wire harness to tweak my fuel consumption. It also sets the vtec point too as i recal.
The 2nd item i have is a unused lil cigar-shaped apexi auto-turbo timer. i think it measures and displays the AFR, along with voltage and 2 other measurements besides letting the engine idle for a pre-set time after removing the key, enabling the oil to cool a lil. not sure if it will do much in the VX i'm reswapping back in,since that has its own built-in-oil coooler from what i recall when i removed it yrs ago. Any tips for using this in my Vx? thanks and appreciate all i'm learning so far!
If you don't know your rights, its like you don't have any at all. Pre Paid Legal & ID Theft Services Restoration available... check out
http://www.deantaber.com
