Old 01-13-2017, 07:32 PM   #1 (permalink)
Mazda 3 - '06 Mazda 3 iTouring
An Article on Tire Pressure
This article is written for bikes but would translate over to cars. It covers various loads, rolling resistance, pressure, etc. I found it interesting, perhaps you will also. It is written by an engineer. Here is a link:
http://www.bccclub.org/documents/Tireinflation.pdf
The Following User Says Thank You to dfeldt91 For This Useful Post:
rumdog (01-14-2017)
Old 01-14-2017, 12:40 AM   #2 (permalink)
ScanGauge <3
ThermionicScott's Avatar
I generally think of myself primarily as a cyclist. It's interesting to see the cycling world move toward bigger tires and lower pressures after so many years thinking that skinny tires and higher pressures were the key to efficient riding. And I'm on board -- my favorite bikes have high-quality 38-42mm tires at Berto-approved pressures, and it doesn't seem to slow me down.
I think the difference is that while some energy is no doubt lost when a car's suspension bounces, the engine's output isn't nearly as affected as a bike rider's.
Best tank (so far): 32 MPG
Old 01-14-2017, 09:46 AM   #3 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Frank Berto! Great guy.
The Following User Says Thank You to wdb For This Useful Post:
ThermionicScott (01-15-2017)
