Old 05-09-2012, 01:27 PM   #21 (permalink)
Water pump and thermostats have greatly increased in reliability . thermostat would need replacing multiple times in 100k time-frame . Now they last 100k on many vehicles , that said there no excuse for mounting/placing the stat in hard to get at place as location is not that important .
Old 05-09-2012, 01:30 PM   #22 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
To drag this thread further off topic Some serial hybrid systems for buses are using two turbine engines. This allows one engine to operate at peak efficiency to meet the base load and the other to charge the batteries and/or provide extra power when needed.
Old 05-09-2012, 01:56 PM   #23 (permalink)
Turbine engines don't have to match RPMs.
I wouldn't trust VW/Audi with anything more complicated than a hammer and nail.
Old 05-09-2012, 02:15 PM   #24 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by tjts1 View Post
I do not understand the complaint. Clearly, the thermostat is accessible.
See, it is visible in this photograph!!!
Old 05-09-2012, 02:53 PM   #25 (permalink)
Fiat multiair do same thing better and easier.
Old 05-09-2012, 03:13 PM   #26 (permalink)
I'd get access with this tool:
Old 05-09-2012, 05:43 PM   #27 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Yet they also don't like to operate at low loads.
Plenty of warships had 2 different sets of gas turbines, a pair of small ones and a pair of big ones to better match the engines with the actual power requirements.
The Following User Says Thank You to euromodder For This Useful Post:
ConnClark (05-09-2012)
