Old 07-29-2008, 07:44 PM   #1 (permalink)
Auto transmission with the manual shift feature
So I have this manual shifting feature as part of my "automatic transmission." Would using this feature to find my most efficient cruise speed (lowest speed in highest gear) be a good tool for maximizing mpg? Or is there something about this manual shift feature that eliminates/decreases the perceived benefit of manual over automatic transmissions?
Thanks.
Old 07-29-2008, 11:20 PM   #2 (permalink)
My wife's VW Rabbit has this feature and I tried it a couple of times.
It kind of works, but it won't let you choose any gear you want. Let's say you want to shift into 5th doing 25, it just will not do it at this low speed. Basically I was constantly trying to get into higher gears.
You also have to push the shifter to the side, which makes it harder to shift into neutral for coasting.
I don't use it anymore whenever I drive her car, drive in D instead and can shift into neutral at any given time.
Old 07-30-2008, 05:07 PM   #3 (permalink)
Kawi - '04 Kawasaki Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Chevrolet Monte Carlo Z34
90 day: 26.52 mpg (US)
Mazda - '10 Mazda 3i
90 day: 35.15 mpg (US)
I had an '07 Dodge Caliber and it had the same thing. It was almost worthless. It wouldn't shift smoothly and like what was said it wouldn't let you pick the gear you wanted if it was below a certain rpm range. Being able to shift into neutral is much more useful.
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
Old 07-31-2008, 09:47 PM   #4 (permalink)
E-Class - '04 MB Mercedes E320 4Matic
Matrix - '09 Toyota Toyota Matrix 2.4L AWD Sports Package
There is such a feature on my 04 MB E320 4Matic. Like JustJoey described above, I can use the feature to urge the car to up shift to the 5th (OD) gear at, say, 50 kmph (instead of at a higher speed if I do nothing) in order to save some fuel.
Old 06-17-2009, 12:50 AM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Hello -
It would probably be really hard to do, but it sounds like this is programmed into the ECU/PCM. In a perfect world, you would be able to REprogram the ECU/PCM to obey your shifting demands. I would make the only restriction to be based on the "minimum safe idle rpm", i.e. something like this :
Code:
new_drive_ratio = get_drive_ratio_from_shift_request( shift_up);
new_rpm = rpm_equation_from (  new_drive_ratio, current_mph, current_LOD);
if ( new_rpm > minimum_safe_idle_rpm )
{ // then
    shift_gears( shift_up);
else
    ignore_driver_request();
CarloSW2
American Solar Energy Society
Old 06-17-2009, 07:32 AM   #6 (permalink)
Driving the TurboWeasel
It's useful for highway driving in the 09 Honda Fit. The system in there does respond to your requests pretty well, and can be used to force shifts even when not in manual mode. Getting out of the low gears and into 3rd at about 25 mph is great for city economy. The transmission programming doesn't let you get into 3rd until ~30 normally.
2012 Chevrolet Cruze Eco 6MT
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
What's the best manual transmission oil? paulwelkins EcoModding Central 19 06-17-2013 10:27 AM
NO Damage to auto transmission by EOC ScottC33 Hypermiling / EcoDriver's Ed 35 07-09-2009 02:42 AM
My auto transmission is clunky! Help! bennelson Off-Topic Tech 6 03-14-2008 05:50 PM
SAAB's (old) freewheeling manual transmission MetroMPG General Efficiency Discussion 1 01-23-2008 03:32 PM
