Old 02-01-2013, 03:54 AM   #1 (permalink)
VSS signal incorrect
I've took a Arduino Nano v3 and added the signals from my ECU (fuel usage) and conditioned VSS signal. Everything seems to work, when I drive a bit it gives me a speed, and a fuelconsumption. The last part seems accurate, but the speed isn't.
While cruising at a constant speed the speed the speed jumps up and down. But what's even more strange, is the first 2-3 stops the speed drops to zero, but after a couple of miles driving the next stop the MPGuino still thinks I'm driving.
Does anyone have a clue what might be wrong?
Old 02-04-2013, 07:35 AM   #2 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
You may try shielded wire for VSS signal. It seems that your wire is catching some external noise.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 03-02-2013, 06:26 PM   #3 (permalink)
Gasser - '94 Honda Civic VX
I have a 94 civic DX coupe, should be the same as the 95 4dr in the MPGuino wiki which says 8214. I had to set it to 10400 to get close, and another thing is regardless of what I put in the "timeout" it won't seem to turn off itself. 7 minuites? I've waited HOURS
My suspect, is the 1.0.3 arduino software to load the uno.
In the sketch it says /* YOU NEED TO USE ARDUINO VERSION 0011 !!!!!! */
//it won't fit with the new math libraries that come with 0012, sorry.
version 0011 will not run on my machine, can anyone address both our problems?
Old 03-04-2013, 03:15 PM   #4 (permalink)
I've found out what the problem was. I used my laptop to power the Arduino (through USB) and I didn't have an extra groundwire from the arduino to the car. That caused false positive pulses. Once I'd changed to power from the car the problem disappeared.
The Following User Says Thank You to Ep Woody For This Useful Post:
AndrzejM (03-05-2013)
Old 03-05-2013, 04:28 AM   #5 (permalink)
Like a 2CV only newer
stargazerf3a's Avatar
Booboo - '06 Renault Clio 2 PH.3 LPG
90 day: 34.69 mpg (US)
I had the same problem with vss signal and all i did to solve this was to connect the negative pole of the mpguino to the chassis and not to the battery pole...
