Old 09-28-2014, 11:26 AM   #1 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Did you know? Suzuki Swift/ Geo Metro water pump
Did you know the Suzuki Swift 1.3 water pump (not sure if the Eco choice 1.0 is the same) is common with a Holden 5.0l V8?
I'm thinking if that's the case then there's potentially a big gain to be had from switching to an electric pump. Anyone like to guess as to how different engines with obviously widely differing cooling requirements use the same pump?
The good news is that because modding Holdens is popular here, you can get a block off plate or adapter off the shelf:
DC8600 Holden V8 253 308 Electric Water Pump Adaptor KIT Davies Craig | eBay
Old 09-28-2014, 02:50 PM   #2 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 42.77 mpg (US)
Check to see if the pumps are running at the same ratio of pump speed to engine speed in the different engines. If the cooling system in the smaller engine has low restriction to flow, a large pump running at slow speed is a very energy efficient solution.
