Old 01-01-2010, 05:03 AM   #1 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Hacking air pressure sensor for fe?
My diesel has an air pressure sensor just after the turbo. I'm wondering what the effect of changing its signal could be. Would tricking the ECU into thinking the pressure is greater (more air) or smaller (less air) result in using slightly less fuel for the same amount of work? On the other hand, the ECU's map could already be fine-tuned to the lowest possible fuel consumption and fooling around with the signals would reduce fe, increase emissions, or both?
I'll add that my turbine is supposed to have variable geometry, so hacking the pressure sensor may put more or less air into the cylinder. Or maybe manually changing the turbo's geometry would be a better idea? Then the ECU could compensate for more/less air in the most efficient manner?
Old 02-13-2011, 03:20 PM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
In two new threads (1.9L VW/Audi/Skoda/SEAT Diesel Mod alert! and Diesel mods and testing) there is quite a bit of discussion about how to put more air into the cylinders of a turbodiesel (better intake ducting) and whether or not this causes more fuel to be used.
Tampering with airflow meters, air pressure sensors, and variable turbine geometry is another way to "fool" the ECU into packing more air. So is this a good route to go down? Also, if I fool the ECU into thinking the (post-turbine) air pressure is lower than in reality, then will it change the turbine's geometry to compensate? Will the (pre-turbine) air flow meter's readings be used to confirm the air pressure sensors signal, so should that be tampered with, too?
Old 02-13-2011, 03:36 PM   #3 (permalink)
Maybe there's a way to hack the "variable" part of the turbo so that it doesn't compress the air as much (heating up the air). If the air is cooler you "should" get better FE.
Old 02-13-2011, 03:37 PM   #4 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
i suspect this would cause problems with running lean. if the computer thinks there is less air going into the engine than there really is(or warmer air) it will inject less fuel. yeah this could effect fe in a positive way since you are injecting less fuel, but i suspect that running lean for extended isn't any better for a Diesel than it is for a gasoline engine.
NOTE: I am not, nor have i ever been an expert in regards to diesel engines, this is only my thought as to what would happen
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
start to play with IAT sensor on Mercedes E250D-Turbo 98' poisas EcoModding Central 6 10-07-2013 04:13 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
