Old 04-23-2025, 06:55 AM   #1 (permalink)
HC fuel to heat/light to solar electricity: 40% efficient, currently..!
So an internal combustion engine with no moving parts (silent and long? lasting) that turns fuel into heat/light that's collected by solar cells specific to that light's frequency, with NO power or energy density limitations..!
At an efficiency of 40% in it's infancy..!?
That's worth keeping an eye on.
Old 04-23-2025, 01:36 PM   #2 (permalink)
I only watched the first one. I know I posted about something similar, but shan't look for it.
With combustion to photoelectric effect, what happens to the heat produced?
Old 04-23-2025, 05:51 PM   #3 (permalink)
Send a message via MSN to markweatherill
The second video kicks off with talk of 'high-temperature heat' which I found funny.
Old 04-23-2025, 06:15 PM   #4 (permalink)
The worst kind.
Old 04-23-2025, 11:13 PM   #5 (permalink)
90 day: 29.78 mpg (US)
If the Rube Goldberg chain of energy transfers is long and complex enough, there's no end to the perpetual energy that could be produced.
Old Yesterday, 07:32 AM   #6 (permalink)
Heat is measured in Watts
Temperature is measured in degrees Celcius, Farenheit, Kelvin, etc.
So NOT!!! the same thing.
You can have a lot of low temperature heat. eg: a hot day
Or you can have a tiny spark at 1000s of deg C, but you wont be causing a hot day with it..!
The confusion of heat and temperature is everywhere and a source of great amusement/sadness.
freebeard (Yesterday)
Old Yesterday, 07:41 AM   #7 (permalink)
You should look up the distinguised scientists telling the world that heavier than air flight was impossible, just before the Wright Brothes took off...
(Like thats going to happen! )
J.P. Morgan was into the "Make copper wire and electricity!' while your ancetors? where calling it 'New-fangled Balderdash'.
Where might you be had they done what he did..?
NB that plain old thermoelectrics, that you can buy right now, are now heading above 10% efficient, while small model aeroplane engines are at around 8%.
SO
NB
The bit where I say it's worth keeping an eye on
THEN
decide I'm a useless dreamer, posting pie in the sky BS beter ignored.
(oops! Too late for that!..? )
