Old 07-14-2009, 03:15 PM   #1 (permalink)
Pot Box Question
Hello to all,
I have an Alltrax AXE 7245. There is a label that says "0-5k ohm"
Now I have a pot box pb-6 i believe. It has two wires coming out of it.
My question is this, how to check if i have a pot box that is 0-5k or 5-0k????
I tested it with my analog tester... and the reading was....
when not stepping on gas = the needle is on the extreme right
when stepping fully on gas = the needle reads between 5 and 4.5 (i guess k ohms)
So does that make sense?
C
EV59rag
Parting out my EV.
ES-31C D&D Motor
Alltrax 7245 Controller
Paul & Sabrina's Controller (never used)
Old 07-14-2009, 03:52 PM   #2 (permalink)
PaulH
MPaulHolmes's Avatar
My analog tester all the way to the right means 0 Ohms. You have a 0-5k Pot. Everything is a go! You will never forget the first time you take a drive in that thing. Enjoy it!
kits and boards
Old 07-14-2009, 03:56 PM   #3 (permalink)
Ford Escort 2.0
TomEV's Avatar
Electricar - '89 Ford Escort LX Hatchback
My PB-6 has two sets of wires coming out of it - a brown/blue pair and a black/white pair. You will want to use the black/white pair.
Black/white starts at zero ohms (short - full deflection on an analog meter) at 'throttle off' and goes to a bit higher than 5k ohms at full throttle.
Brown/blue pair starts off at about 5k, and goes to about 10k. Not used in my Alltrax application. - left disconnected.
Your pot box may have different wires - in any event, it sounds like you tested the correct ones. You can test it with the Alltrax and a computer to make sure you get full throttle range (0 to 100%)
Hope this helps!
Tom
Old 07-14-2009, 04:21 PM   #4 (permalink)
Thank you all, Im excited to finish the wiring this afternoon and to experience the EV grin. Tom, I have the black and white wires and no brown or blue. So im set.... I hope i dont blow anything.
wish me luck...
EV59rag
Parting out my EV.
ES-31C D&D Motor
Ben Nelson's Electro-Metro Build thread bennelson Fossil Fuel Free 1499 12-22-2019 07:24 PM
Zemco Compucruise 44 New In Box... clbolt For Sale 29 06-25-2013 06:18 PM
Radiator relay/sensor question Piwoslaw Off-Topic Tech 8 06-07-2012 05:54 AM
Tires question RandomFact314 EcoModding Central 18 04-20-2009 11:30 AM
newb intro and question about civic hb vx reformed Introductions 9 01-29-2008 11:28 PM
