Old 10-06-2008, 03:51 AM   #1 (permalink)
Send a message via MSN to markweatherill
Battery to starter cable fault
I have what appears to be a faulty cable from the battery to the starter. It's been turning the engine over slower and slower until finally I had to investigate. Wiggling the end of the cable at the starter appeared to fix the problem for now.
I will renew the cable ASAP. But meantime could this also be the cause of a general lack of power? At the same time as the starter began churning slowly, the engine seemed to have no real 'go' on the open road. Is that possible?
Old 10-06-2008, 09:40 AM   #2 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
check the ground cable too, there should be one between the frame and the engine block as well, I've seen starter cables burn out before, not real common but it happens.
Old 10-06-2008, 12:41 PM   #3 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Possible depending on the vehicle. At least on mine, the starter is acts as a junction block as well. The alternator cable goes to the starter, then goes to the battery. So if that cable was bad, the battery would run down, and it would run worse due to low voltage problems.
Winter daily driver, parked most days right now
Summer daily driver
Old 10-06-2008, 02:39 PM   #4 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Cleaning all your grounds/connections should help. I've never heard of a cable being bad, just rust/oxidation on connections
Old 10-09-2008, 01:12 AM   #5 (permalink)
It wasn't the main battery cables after all. It appears to be the wire frm the 'M' terminal into the starter itself. Of course I can *see* it but can't reach it without some major dismantling...
Alternator Delete VS starter motor bennelson EcoModding Central 25 02-04-2017 11:03 PM
cheap, light-weight EV battery? eta Fossil Fuel Free 5 05-15-2009 01:00 AM
Correct battery voltage ? groar Off-Topic Tech 2 09-23-2008 09:13 PM
Starter went out millenniumtree EcoModding Central 9 08-25-2008 11:15 AM
Split battery power apgrok1 EcoModding Central 3 03-13-2008 09:59 PM
